Author Topic: Fibre cloth and boat hulls.  (Read 3510 times)
zetec
« on: September 26, 2006, 04:08:50 pm »
Now I'm getting on with my Veron Police launch creation I'm starting to get nervous about it being water tight..I did see at a recent show a stand selling fibreglass cloth and resin for covering this sort of this and very good it looked too. Having tried to use fibreglass before I suspect it takes a bit of doing to get as perfect as the demo piece looked.
Any tips? I was thinking of using very light cloth (25g) and cutting and fitting in different pieces to best follow the hull shape. Or just painting the hull in the resin without the cloth just to make it water tight.
Suspect if it goes wrong all my hard work will end up in a sticky mess in the bin.
boatmadman
Re: Fibre cloth and boat hulls.
« Reply #1 on: September 26, 2006, 04:26:56 pm »
Hi
I have used both resin on its own and resin with cloth.
The main thing is to have a sound and clean hull, with no lumps bumps or gaps,  sand it down v smooth, clean with white spirit, then clean with acetone - available from hairdresser suppliers!
You will need 2 coats of resin whichever way you go, if using cloth, apply a thin coat, wipe off the excess with card, cut up from cereal packets, and lay the cloth over the hull in one peice, it will absorb into the resin. When all is set and hard, trim off the excess cloth and recoat with resin. This will both waterproof and strengthen your hull.
Aim to get the second coat of resin within 12 hours of the first if possible, this will give a chemical bond rather than a mechanical bond, and is much stronger. Dont be surprised if the final coat takes a few days to harden properly, oh, and try not to do it in damp or humid conditions or you may get a 'bloom' a milky white colour on the resin - ugly more than harmful.
The use of cloth primarily gives stregth, the resin waterproofs.
Then, smooth off the resin when hard using v fine wet/dry - its a long slow process but worth the effort. Try to avoid sanding back to wood, or you will need more resin!
Finish to your choice - paint or varnish.
I have used this method on models and 1:1 scale - it works for me!
have a look at the slo mo shun build log on this forum, there are resin related comments on there too.
Good luck
Barthez
« Reply #2 on: September 27, 2006, 01:22:04 am »
I always coat my boat hulls in glass cloth.
I use more or less the method in the post above but for the second coat of resin i mix the resin with a powdered filler or talcum powdre to thicken it up. I apply small amounts of the mixture and use a crdit card sized piece of plastic to smooth it out and fill the weave of the cloth.
The thickened mixture fills the weave of the cloth better than  resin alone and more importantly it makes the resin easier to sand.
Bart
cbr900
  • Mayhem is the Only Forum!
    • Roys Hompage
« Reply #3 on: September 27, 2006, 03:04:31 am »
Another good tip is thin the first coat of resin, lay your mat then roll with toilet roll, smooths out the mesh and removes excess resin, then apply second coat  fairly thick the talc is a good thickener, sand with wet and dry, paint to your hearts content, with the knowledge that your boat will not leak....
Roy
boatmadman
« Reply #4 on: September 28, 2006, 07:25:00 am »
How much talcum do you use? And does it make the boat smell nice?  ;D
« Reply #5 on: September 28, 2006, 08:51:58 am »
Any particular make of talc? ::) ::)
cbr900
    • Roys Hompage
« Reply #6 on: September 28, 2006, 10:38:28 am »
I do not know what you can get over there but here I use good old Johnsons Baby Powder, works for me and the boat never get a rash...
Roy ;D ;D
