Author Topic: lead acid vs nicad  (Read 3815 times)
tomocj
lead acid vs nicad
« on: February 06, 2009, 08:49:43 pm »
What are your thoughts on the choice between lead acid and nicad batteries ,which are best suited to model boats,is it a question of type of hull ie high speed planning lighter nicads and heavier hulls tugs etc using lead acid for capacity and weight /ballast?
Any thoughts welcomed
Re: lead acid vs nicad
« Reply #1 on: February 07, 2009, 12:57:19 am »
I aint no expert on this subject however:- I use sealed lead acid batteries whenever possible and locate them as centrally as possible and as low in the hull as possible.
Built 8 boats - 6 use the SLA batteries - these vessels are tugs and fishing boats. The other 2 boats are fast electric for which I use Ni-Cad "six-packs" 1800 and 2400 capacity. O0
« Reply #2 on: February 07, 2009, 09:52:52 am »
I don't think you can get NiCads any longer, just NiMH which are greener and generally better.
tomocj
« Reply #3 on: February 07, 2009, 10:14:52 am »
Thanks for that I did mean nimh not nicad ,It seems sensible to use SLA in the larger Hulls saves adding weight .Chris
tony52
« Reply #4 on: February 07, 2009, 11:09:31 am »
Do the newer and greener NIMH have the problem of memory locking, which plagued the old NiCads? Didn't the old Nicads had to be fully discharged before recharging to prevent this?
I have just bought my first NIMH pack and would be interested to know.
Tony.
« Reply #5 on: February 07, 2009, 11:12:45 am »
No, the NiMH cells are essentially free of the memory problem that affected Nicads but you should still charge them as recommended.
« Reply #6 on: February 07, 2009, 12:03:59 pm »
Tony.
Hi Tony, no you dont have to discharge NiMH packs before charging as you had to do with NiCADS
tomocj
« Reply #7 on: February 08, 2009, 02:43:57 pm »
Anyone used Li-po in boats??
Chris
Islander1951
« Reply #8 on: February 08, 2009, 05:28:42 pm »
Li-po batteries are a completely different ball game.   They are great if you need high power, low weight and fast discharge , e.g. brushless FE boats.
   However they need a special charging system , and are not as robust as  NiMH packs.  Don't drop them on anything hard , or they may become damaged , then they must be discarded .  Charging damaged cells may , in some cases , lead to them exploding !!!
      Lots of info out there , just be careful.
        Islander51
nick_75au
« Reply #9 on: February 09, 2009, 07:53:27 am »
I use a 7.2v 350 mAH Li-po in my 1/72 Revell Schnellboot, only because other types of batteries are too heavy. they are also good for a lot of capacity in a small space. the equivalent in Lipo takes up 1/4 the space of Lead acid
Nick
tomocj
« Reply #10 on: February 09, 2009, 09:15:10 am »
Thanks for your in-put ,I have used Lipo in aeros not bad results but I still prefer a proper engines Diesel and glow.Just wondered if many boaters had switched to Lipo.
Started boating as it is the building I enjoy and probably less chance of a total wipe out than aeros.It is sad to see a plane in more pieces than when you started building it Ha Ha.
Chris
