Author Topic: live steam injectors  (Read 4270 times)
knoby
« on: February 12, 2009, 09:09:13 pm »
has anybody had experience of using live steam injectors to replenish boilers?
i have never heard of this being done in a model marine boiler  & theres probably a really good reason for this. but i dint know what the reason is.
can anybody enlighten me?
 cheers glenn
bogstandard
Re: live steam injectors
« Reply #1 on: February 12, 2009, 10:11:17 pm »
Glenn,
I tried many years ago to run A Cheddar Puffin plant with an injector, and it was almost a total failure.
I say almost, because I did get it to work after a fashion, by taking the boiler very close to it's upper limits, and only then with no other steam being used, the engine was stationary.
I was using the smallest injector available, and there just wasn't enough pressure or volume from the boiler to get a continuous flow of topup water. It is still in a box somewhere, destined to be forgotten.
I suppose with one of the larger Stuart boilers, it might work, but I think you would be banging your head against a brick wall with the standard size of marine boilers.
« Reply #2 on: February 12, 2009, 10:46:18 pm »
As John has said, you need a fairly large boiler, with a good steam pressure just to make the injector work. Works on loco's as you have a driver, large boiler and hands on control.
My advice (same as Johns) don't even go there
Besides injectors are bl**dy tricky things as the best of times.
Clack vavle, simple.
Phil
knoby
« Reply #3 on: February 13, 2009, 07:20:52 pm »
thanks guys, i kinda knew that was going to be the answer. i had a 5 inch gauge simplex for a while & even then the injector was a bit temperamental to say the least !!!
i just wondered if they had evolved much.
its a shame, replenishing the boiler with hot water would be so nice so i guess its back to the mechanical pump for me lol
thanks Glenn
Page created in 0.013 seconds with 17 queries.
