November 16, 2025, 11:14:46 am
Welcome,
Guest
Please
login
or
register
1 Hour
1 Day
1 Week
1 Month
Forever
News:
Home
Help
Search
Calendar
Login
Register
Mess Deck: General Section
Model Boating
WOT Thicknesser???
« previous
next »
Pages: [
1
Go Down
Print
Author
Topic: WOT Thicknesser??? (Read 2671 times)
badgerballs
Guest
WOT Thicknesser???
on:
February 15, 2009, 03:23:57 pm »
Well I really don't know what root to take here. I want a thicknesser to be able to create my own veneers of 1mm-3mm in .5mm stages. For example I would like to make planks out of loads of 1"*6" planks. So I would rough out say 2-3mm*1" strips on my band saw and then run it through the thicknesser to get down to 1mm*1". I could then run the strips through my proxxon table saw to get 3mm*1mm planks. I would also like to run some of my existing balsa stock that is 4" by 1/8" down to 2mm thick.
So down to the thicknesser. The proxxon is no doubt accurate, but expensive for what it is and only allows a width of 3ins. So I spotted this one the SIP01497
http://www.sipuk.co.uk/tools/info_SIP01497.html
. Does anyone know if SIP or similar will do the job as I require or is it only the proxxon that accurate enough?
Bartapuss
Full Mayhemer
Offline
Deltic's Rule OK!
Somewhere up North
Re: WOT Thicknesser???
Reply #1 on:
February 15, 2009, 03:48:06 pm »
The SIP looks as if it more for furniture/light building work and made down to that price listed, I have heard good reports regarding the Proxxon which is custom made for precision modelling work.
Every time I learn something new, it pushes something old out of my brain - I says wot I likes and I likes wot I say!!!
Bee
Guest
Reply #2 on:
February 15, 2009, 10:33:41 pm »
Have you considered, except for the 4in width, an ordinary hand electric planer with spacers taped to the sole plate?
FullLeatherJacket
Guest
Reply #3 on:
February 15, 2009, 11:32:00 pm »
A planer/thicknesser might be too powerful for that sort of dimension. Commercially, balsa sheet is sanded to final thickness after roughing on a bandsaw with roller feed. Have you thought about using a belt sander instead?
Suit yourself.
FLJ
Proteus
Guest
Reply #4 on:
February 16, 2009, 12:53:59 am »
These may give you a few ideas
http://mysite.verizon.net/ELLshipmodeler/sander.htm
http://www.byrnesmodelmachines.com/sander.html
http://www.modelshipbuilder.com/resources/thickness-sander.html
http://www.preac.com/thickness_sander.htm
Proteus,
Print
Pages: [
1
Go Up
« previous
next »
Model Boating
WOT Thicknesser???
