Hello and welcome to my build thread. Looking around the site there is great interest in the OMRA racing side of things, but no threads on actually how to build one. I decided to take up the challenge, I am showing this as guidelines of what to do, and am seeking knowledge on what I should do all the time from people at the club, mainly Greg, who has been model boating since what appears to be the dawn of time, because I have yet to meet anyone more clued up on IC boats. I offer this information to you as not "you should do this and this only", because everyone has their different ways of going about doing things. I would also like to point out that I'm only 17, and have only been boating for 3 years now, so I'm far from the best out there, but contrary to popular belief I do listen to everything that I'm told, and absorb it like a sponge....
I bought this boat, a Crusader 3, moulded by Bernard Holder, at the Stevenage OMRA race last year. The hull is for up to a 7.5cc (.45 cu i), and is 42" long by 12" wide. I've been talking about making this thing for ages now, and have finally got round to doing it. Many engines have been suggested over time, among which Picco .45's, OS .45's, and a Zenoah, the idea of which was rather forcefully rejected by just about everyone except Bill and Greg, even the maker had words to say about it (see the Mental Makara video on my site for why, except instead of only 2cc more than suggested, I was going for 18.5cc more...). I have settled on a Novarossi CX61, bought off Greg, Still too big but plenty controllable enough.
I must admit beforehand that I am useless with Polyester Resin, it ends up everywhere, and doesn't look good. But it's very cheap and reasonably light. I used Talc to thicken it up when layering for strength.
This so far is two day's work.
Enjoy
The finished Boat:
My boat, control and engine.
Engine in hull
Engine and MAC pipe
Marking the hull
Filling a chip in with P38
Rudder tube installed
Rudder installed
Components in boat.
The 'destructions'
Having read the destructions, I sanded the filler in the chip down
Pilot drilling the driveshaft slot
Cutting filing and enlarging the slot
Cutting and fitting the strut
Following a trip to school with engine and strut in bag, the mounts were filed with flats, to keep them in the boat, and the strut was cut down. This is the P38 over the first layer of Polyester Resin.
Polyester resin was used to secure all parts in, before P38-ing, and a coat of thickened Resin.
Tacking the mounts in with P38, so the engine can be removed.
Building up Polyester Resin and P38 around mounts.
Same as above, but on the other side.
Building up P38 and resin around the shaft, a Prestwich model, but heavily modified for me by Ralph, the club metal man. He changed the bearing feed from a grease nipple to oil feed, cut the shaft and tube to length, brazed on a new tube that actually fits properly onto the strut, and many, many more things that I can't think of right now. All his work is beautifully done, very neat, and he polishes everything afterwards. For a very handsome price too.
Resin, Talc and Glassfibre matting around the mounts. I did 3 layers of Resin and glass, and 3 layers of P38 on each mount. It's VERY strong.
Slightly neater one...
The penultimate coat of Polyester Resin and Glass Mat, mum thought I was bleeding everywhere...
The finished mounts, where I have got to so far.
That's as far as I have got so far, after about 6 hours work. More will follow shortly, Equipment to be fitted is:
- Radio box, a highlander metal sandwich tin, with latching lid. Race proven and crash tested in Bill's Makara, so it's good enough for me. will be on 5" rails made from 1/8" ply.
- 2 Futaba S3003 servo's, one for throttle and one for the remote mixture needle.
- 1 Cirrus CDS751 servo, for rudder. Cheap at £20, standard size, digital, metal geared, and twice the torque of a S3003
- Spektrum radio gear, no arguments please...
- The biggest Rx battery pack I can possibly fit in, looking at a 5 cell Sub C pack from Ansmann, with Rx leads and Tamiya connector for charging already fitted
- Sullivan Snakes for Throttle and remote needle, and Du-Bro Heavy Duty joints and rods for the rudder
- 2 fuel tanks, big as I can get in, and most likely a float chamber too
- A support for the pipe
- Pool Noodles!
I'm toying with many ideas for paint jobs, but I personally think it looks like a PT boat of sorts, so I think it will be painted a deep green, and I'll get RCGraphics to make me up some big shark mouth stickers for the front. The inside will be sprayed with Halfords grey primer, and fuelproofed. This is so I can see things in the bottom of the boat when I drop them...
Next job will be to fit radio box in on rails, and then join the deck to the hull.
