Dan,
Good news - if you have the tune, you have all the coils intact and also the magnets are alive
I was going to run you through the basic electrical checks, but I think you have done that
Right - how does the motor turn over? Does it turn?
I suspect that the shaft may be bent, or the bearings doinked.
How are you trying the motor? using ESC/battery pack/receiver/transmitter?
If you are doing this you:
Turn on the Tx - put throttle in Off position (important)
plug in the battery pack to ESC (tune plays)
OR plug in battery and turn on arming switch (tune plays)
advance throttle a little - motor should try and turn - it will kick, whine and may oscillate
Does it try to do anything?
Turn everything off - is motor warm?
Can it turn freely? (you should feel the "cogging" of the magnets but it should be mechanically free
does the rotor go round concentricallly of does it swash?
Does it dismantle? simple motors just pull the bell off the stator - its retained by the magnet force (even with a air propeller!)
Others have a circlip on the shaft or some other fixing
Replacement shafts and bearings are readily available for most motors - (the "careful" owner can straighten shafts)
Pictures? Type?
will help more if I can
andrew
