Pages: 1 2 [3] 4 5 6 7 8 9 10 11 12 13   Go Down
Author Topic: Bourbon Orca  (Read 175968 times)
PeterS
Re: Bourbon Orca
« Reply #50 on: October 01, 2009, 04:31:42 pm »
Ok, same story ...
If someone can help me out?
I'm using firefox (with noscript), but all restrictions are switched of.
A new window poped up, "browse files", and some secs the file is uploaded to  öhh.. -nirwana?
(and what the h.ll is "hotgirls4..." ???)
anyway, no pictures here...  <*<
 Aft deck without the dummy and visible sealing (a kind of tupper ;-)
Dummy deck
The main engines, between 2 pumps to supply the rear thrusters
Sorry, can't find some pics of the opened superstructure actually.
The main winch and all parts on aft deck remain on its places. Crucifix ist devided, and I can pull out deck 1+2 with crane, FRB, secondary winch and all parts added on the rearplane of superstructure.
It's a little bit tricky, but: That's modeling ;-)
Pete
Voyager
Re: Bourbon Orca
« Reply #51 on: October 01, 2009, 04:37:06 pm »
Lovely work Pete....and those containers on the deck look superb, very nice indeedy!!!!
I'll be watching this one closely, can't wait to see the detailing and the painting to come  :-)
cos918
Re: Bourbon Orca
« Reply #52 on: October 01, 2009, 06:02:32 pm »
Hi  Peter.
I thought I recognised your boat . I have been following your build on a different web  site. Most impressed.
http://picasaweb.google.de/Peter.S.aus.O/NewProjects#
PeterS
Re: Bourbon Orca
« Reply #53 on: October 01, 2009, 07:05:48 pm »
THX!
John, you're right ;-)
But i wouldn't bump this thread of Ian with my pictures....
Pete
boatmadman
Re: Bourbon Orca
« Reply #54 on: October 01, 2009, 08:37:03 pm »
Got a bit bored building the hull, so I decided to start on the bridge deck and superstructure.
The bridge looks too small, but I have checked the dimensions about a dozen times and they are right - will look better when its finished - I hope!
Ian
PeterS
Re: Bourbon Orca
« Reply #55 on: October 02, 2009, 03:42:18 pm »
Hi Ian
you asked about the openings..
The "drawer" ...
and the remaining hole
boatmadman
Re: Bourbon Orca
« Reply #56 on: October 02, 2009, 04:30:57 pm »
Peter,
Thanks, thats a good way of gaining access, I was thinking along th e lines of lifting the bulkhead vertically, but your idea is better - more room for fingers! :-))
Ian
boatmadman
Re: Bourbon Orca
« Reply #57 on: October 03, 2009, 06:43:44 pm »
spent today on the bridge structure, think I threw away as many pieces as I fitted, devils job getting all the angles cut right!
Ian
PeterS
Re: Bourbon Orca
« Reply #58 on: October 03, 2009, 10:17:38 pm »
WOW!
Bridge is a fiddly (?) work to do, but it looks fine, well done!
Dimensions seems to be correct- my own bridge is a bit oversized, I forgot the socket and added it later. Therefore my bridge looks ~8mm higher.
Is there any supporting/stiffening  structure inside the ABS plates?
(If you want to lift off the bridge later, it would be essential)
CU
Pete
boatmadman
Re: Bourbon Orca
« Reply #59 on: October 03, 2009, 11:31:40 pm »
Fiddly describes it just fine!
There are no supporting structure yet, but there will be, probably in the form of control desks around the structure,and floors.
Ian
Umi_Ryuzuki
Re: Bourbon Orca
« Reply #60 on: October 04, 2009, 02:39:54 am »
Ian,
Looking great as usual.  :-))
Peter,
Nice of you to lend a hand. It's always
good to see how others have assembled things.
Aimee
PeterS
Re: Bourbon Orca
« Reply #61 on: October 04, 2009, 09:53:57 am »
Hi Umi :-)
Didn't you sleep sometimes?
Is there a forum around the world you are NOT involved?
I might have known it... ;-)
Did you see what Ive done to your floodlights?
(in the photoalbum, near at the end)
It's the best solution at yet. 3 sunny-white SMT LEDs + resistor are inserted from the rear side.
Tey are very flashy at ~15mA!
For the first version I forgot to paint the reflector in silver, and now you can  see a "black hole" when switched of.
But that's no problem,  actually there is no application to use for, and for the next time I know how to do.
CU
Pete
PS:
I've managed to go to Heemskerk next weekend, and meet the guys of SMG Ijmond and probably some of the IOS.
Shure, this will become a fine meeting :-)
boatmadman
Re: Bourbon Orca
« Reply #62 on: October 16, 2009, 03:46:39 pm »
No progress to report folks - been working stupid hours and will be till the end of the month, hopefully I will be able to re start then.
Ian
swampbug
Re: Bourbon Orca
« Reply #63 on: October 16, 2009, 09:26:04 pm »
Ian
Im not one to read so im afraid i havent read all on here.
ut im so impressed with all the pics, she is stunning
What a challenge and hours you must have put in
Great job  :-))
boatmadman
Re: Bourbon Orca
« Reply #64 on: November 04, 2009, 05:05:20 pm »
Back to it at last :-))
Spent all day today building wheelhouse control desks - not much to show for a days work, but they were fiddly, and I had no detail plans, just outlines, so just made 'em up as I went along.
Ian
Re: Bourbon Orca
« Reply #65 on: November 04, 2009, 05:24:59 pm »
Ian,
Wonderful work - compared to my progess on less detailed work on the wheelhouse of my Anglian Sovereign, you have been working at light speed. All power to your elbow.
Doug
Umi_Ryuzuki
Re: Bourbon Orca
« Reply #66 on: November 04, 2009, 07:14:24 pm »
Wow... Nice work...
Now about lighting...  %%
boatmadman
Re: Bourbon Orca
« Reply #67 on: November 04, 2009, 09:31:28 pm »
Thats the sort of thing I am working towards, Umi, how did you do it?
Ian
Umi_Ryuzuki
Re: Bourbon Orca
« Reply #68 on: November 05, 2009, 03:14:36 am »
Ian
Worked them up using renshape.... Styrene would work also(left).
I then made a mold and clear cast them with the LED inside.
boatmadman
Re: Bourbon Orca
« Reply #69 on: November 05, 2009, 06:02:21 pm »
Went out to the garage this morning to look at yesterdays work and discovered I had made one of the control desks wrong handed - made it for the port side, should have been starboard doh!
So, remade that, then went on to some more indoor furniture, then some external fittings and started the mast.
Bear in mind its all dry fitted at the moment, hopefully it will look better when painted and stuck properly.
Ian
AlanP
Re: Bourbon Orca
« Reply #70 on: November 05, 2009, 07:23:27 pm »
Looking good Ian, :-))      my, you do like models with lots of windows in them  :}
Looking forward to helping you launch it, be another launching trolley I suppose , hope this one doesn't float like the last one  %%
Oh, hope you are going to make cushions for those seats in the bridge  ;)
Alan
boatmadman
Re: Bourbon Orca
« Reply #71 on: November 05, 2009, 07:30:40 pm »
Launching will be a while off, Alan, time for you to build  your muscles  :-))
Cushions for seats? This is a working ship, not a liner, blooming crew should just be thankful for seats!
Ian
(working on a sinking launch trolley when I have a mo!)
hama
Re: Bourbon Orca
« Reply #72 on: November 05, 2009, 10:26:52 pm »
Very nice, I feel like taking seat in one of those chairs and head for the horizon! Again an interesting subject and very nicely built.
Hama.
PeterS
Re: Bourbon Orca
« Reply #73 on: November 06, 2009, 05:21:20 am »
Great work Ian!
I'd never had a thought about buildiing the inside of the wheelhouse.
But when I see this ... :o
Go on!
Pete
boatmadman
Re: Bourbon Orca
« Reply #74 on: November 08, 2009, 10:20:24 pm »
Can anyone help me by identifying what colour these lights should be? And under what sequences they should be lit.
The pic is of the Bourbon Orca, and shows the forward face of the mast,
Ian
Pages: 1 2 [3] 4 5 6 7 8 9 10 11 12 13   Go Up
Page created in 0.039 seconds with 18 queries.
