Author Topic: Ripmax NoLimit ESC Speed Controller Setup  (Read 7166 times)
getemuphigh
« on: June 17, 2009, 11:07:13 pm »
Anyone know how to set one of these and are they any good:
http://ripmax.com/item.asp?itemid=P-XTRA-NOLIMIT&selectedtab=060&Category=060-050-110
toesupwa
  • USA'd ex Brit
Re: Ripmax NoLimit ESC Speed Controller Setup
« Reply #1 on: June 18, 2009, 12:52:19 am »
Looks similar to the Associated (car) AI series ESC's..
1/ As long as you can put up with the 'time lag' before you can engage reverse, they are fine. You might be able to programme out the 'lag'?
2/ Ensure you can get cooling air over the heatsink.. in an enclosed boat, the ESC can thermal 'out' until it cools off.
red181
« Reply #2 on: June 18, 2009, 01:45:51 pm »
ring ripmax, there is a guy who specialises in esc's he will talk you through the setup, I did this setting up a Ripmax seasprint esc :-))
HawkEye
« Reply #3 on: June 20, 2009, 06:13:58 pm »
Hi all,
first post so let's hope it's useful !, I have a couple of these that I used before converting to brushless, so hopefully the instructions are attached in pdf format.
getemuphigh
« Reply #4 on: June 30, 2009, 10:18:37 pm »
Hi all,
Great, just what I needed, many thanks! :-))
