Author Topic: FUNTABA R617FS POWER SUPPLY  (Read 3161 times)
paddysdad
« on: July 21, 2009, 03:45:49 pm »
HI. Have purchased a Futaba 6ex/2.4 ghz.With it comes a R617FS receiver on reading the instruction manual it shows a external voltage supply into channel 7/b.The diagram is for aircraft .Do i require this for my model boat if so what do i need. Regards Paddysdad
andrewh
Re: FUNTABA R617FS POWER SUPPLY
« Reply #1 on: July 21, 2009, 04:05:07 pm »
On any receiver (including this one) you can feed the receiver power into any of the channel plugs as well as the one called power (if there is a seperate one).  To keep the size and cost down (and width) a lot of the manufacturers do this and make the highest number channel also the power feed point.
If you have a ESC with BEC (ie it supplies power to the receiver) you do not need to do anything at all - that is where the Rx and all the servos will get the power from
If you are driving servos only, or a ESC without BEC just plug your RX battery into the Channel 7 (or any other unused channel)
BTW - if you are using all the channels and none of them are BEC, then you plug any one of them in to the correct type of "Y" lead (one male to 2 females)  and the battery into one of the females and the servo/whatever into the other - this feeds the Rx and all the servos, etc
Does this answer your question, or help?
andrew
