Author Topic: flexible drive  (Read 3631 times)
mook
flexible drive
« on: August 04, 2009, 09:38:00 am »
Just my mind asking questions again.
We use flexible drives in large petrol powered models etc. But why dont we use them in smaller models apart from maybe the obvious friction. If the drive is only a small way out of line then it should work well, shouldn't it? O0  :P
andyn
Re: flexible drive
« Reply #1 on: August 04, 2009, 12:05:21 pm »
Cheapness I suppose. The 'fast' electric lot use them too. Plus a flexi shaft can only go one way. If done right a flexi has less friction than a straight shaft anyway.
ZIPPY
Re: flexible drive
« Reply #2 on: August 04, 2009, 12:12:24 pm »
Hi,flexidrives are mainly used for surface drive boats and performance power.The flexi enables racers to adjust the angle of the prop, up and down which with a solid shaft wouldnt work.
Re: flexible drive
« Reply #3 on: August 04, 2009, 01:28:57 pm »
I've seen piano wire used in small boats but you do need a bit of engineering skills to make up
couplings and a prop 'counter' (?!?) shaft at the tail end but otherwise a great idea.
mook
Re: flexible drive
« Reply #4 on: August 04, 2009, 01:53:01 pm »
I'm building a Speedline lifeboat and because I am fitting brushless motors it is a fussy job to get the driveline straight, I have managed it but maybe there is a slot for someone to do flexible drive lines for all types of models if there is not a problem with friction slowing everything down. I certainly would have tried some on this model. Thanks everyone
andyn
Re: flexible drive
« Reply #5 on: August 04, 2009, 02:08:24 pm »
As I say you can only go one way with a flexi, under load it'll unravle itself.
Bryan Young
Re: flexible drive
« Reply #6 on: August 04, 2009, 02:48:36 pm »
A hint that brian_c gave me years ago, and has been used very often in models built by both of us is the use of car electric seat motors (predominently from Ford) that have a 2" (approx) flexi drive that can be fitted to either end of the motor. The "spring" for want of a better word has square ends so you need to make up at least one coupling to fit a round shaft. Absolutely superb....especially when used in a model that weighs over 100lb! Takes the strain of going from full ahead to full astern with aplomb. Biggish motors, but still low drain. BY.
Notes from a simple seaman
mook
Re: flexible drive
« Reply #7 on: August 04, 2009, 02:55:42 pm »
Do you need reverse, most models stop quite quickly and if the stop is planned then maybe we dont need it?  {:-{ After all most IC and petrol motors manage to stop , I could be wrong about this I usually am  O0
Page created in 0.035 seconds with 17 queries.
