Author Topic: prop tube  (Read 4008 times)
tomo55
prop tube
« on: August 14, 2009, 02:13:14 pm »
Took apart prop tube from my deans marine ASRL ,there is only one brass bush on the prop tube,is there meant to be two?and would this be the reason why its a bit noisy ?
Silly question probably but I thought there would/should be two brass bushes to support it at both ends.
help please.
chris
chingdevil
Re: prop tube
« Reply #1 on: August 14, 2009, 05:21:00 pm »
There is usually two bushes, otherwise the end without a bush will rattle and also let in water to the model. Is this in a new build, if so contact the supplier, if not you would be wise to make a new bush.
Brian
tomo55
Re: prop tube
« Reply #2 on: August 14, 2009, 07:08:03 pm »
Hi Brian thanks for that ,It did rattle when I tried it I put loads of grease in to stop it but could still hear it.
Ive been building this for a long time so I dont know if Deans will supply another,tried them though.If not easy enough to make up.
Thanks again Chris
Re: prop tube
« Reply #3 on: August 15, 2009, 12:23:34 am »
Deans will supply spare shaft bearings.
My mate just got 8
tomo55
Re: prop tube
« Reply #4 on: August 16, 2009, 12:32:28 pm »
Been in contact with Deans they are sending some bushes / bearings so should have quiet running soon.
Thanks again Chris
Re: prop tube
« Reply #5 on: August 16, 2009, 02:18:59 pm »
My Deans kit had a prop tube with a sort of double bearing arrangement whereby the sleeve rotates in the tube. OK when it's installed but the sleeve can drop out and get lost which is maybe what's happened here.
tomo55
Re: prop tube
« Reply #6 on: August 16, 2009, 04:09:42 pm »
Yes that is probably what happened.
Chris
tomo55
Re: prop tube
« Reply #7 on: August 20, 2009, 04:47:50 pm »
Brushes / bearings arrived so that should get rid of the rattle.
Chris
Page created in 0.013 seconds with 18 queries.
