Author Topic: peco points  (Read 3228 times)
hopeitfloats
peco points
« on: August 15, 2009, 11:57:46 am »
would anyone know where i could get an online wiring diagram for PECO SL E99 3 way electrofrog points. i lost mine and want to check that i have wired correctly. have googled and tried the peco site with no luck. {:-{
Re: peco points
« Reply #1 on: August 15, 2009, 07:12:29 pm »
Don't know if this is what you want, but it's copied from a PECO booklet by Cyril Freezer on wiring the layout.
The following text applies as well:
The wiring gives automatic siding isolation. The frog rails are one electrical unit and are connected to the point blades so that the frog is at the same polarity as the the stock rail against which the the blades are held. this not only ensures that the open track has rails of opposing polarity but also means that the closed track has rails of the same polarity.
HTH
Doug
polobeer
Re: peco points
« Reply #2 on: August 16, 2009, 08:25:14 am »
If you contact Peco directly by telephone (or write) they will send you a replacement diagram free. It's been a long standing tradition of theirs. Here's the link to the phone number:
http://www.peco-uk.com/
Simon
hopeitfloats
Re: peco points
« Reply #3 on: August 16, 2009, 08:48:22 am »
thanks guys. i emailed peco but found the problem since and all is well now. :-))
Page created in 0.053 seconds with 17 queries.
