August 09, 2025, 12:40:18 am
Welcome,
Guest
Please
login
or
register
1 Hour
1 Day
1 Week
1 Month
Forever
News:
Mayhem at Wicksteed -
May 24 25 2025
Home
Help
Search
Calendar
Login
Register
The Shipyard ( Dry Dock ): Builds & Questions
Steam
Monahan Heron
« previous
next »
Pages: [
1
Go Down
Print
Author
Topic: Monahan Heron (Read 4328 times)
Bernhard
Guest
Monahan Heron
on:
August 17, 2009, 08:28:04 am »
Hi,,,,,,,My Friend have get a Heron,,and a Hemmens Boiler,,,,he is start to break it in,,,,he will build a River Queen to it,,,
Regards Bernhard................. i did allso see one on youtube
http://www.youtube.com/watch?v=TAKr6KkmxyM
kno3
Guest
Re: Monahan Heron
Reply #1 on:
August 17, 2009, 10:28:07 am »
Beautiful engine and plant! I guess the water tank is a converted spray can?
By the way, where is the gas pressure valve from?
Bernhard
Guest
Re: Monahan Heron
Reply #2 on:
August 17, 2009, 11:42:19 am »
hi..........he have build many boats
http://home19.inet.tele.dk/cvj/
the gas pressure is from this place...i have one to,,,work ok,,,,,,,,,,,
http://www.forest-classics.co.uk/bix029.htm
here is a nice video of his chalup he can have it on the lake for 45 minuts,,,
http://www.youtube.com/watch?v=owCKmt1neo0&feature=PlayList&p=C2FDAACB30C9C134&index=1
Bunkerbarge
Guest
Re: Monahan Heron
Reply #3 on:
August 17, 2009, 01:06:52 pm »
John Hemmens used to make a very similar unit as well, you can contact him via his web site here:
http://www.steamengines.co.uk/
As regards the Forest Steam item I have to say I think it's a bit much that you are expected to purchase the nuts and cones seperately for another £4.50. On top of the £39.99 that is unreasonable.
kno3
Guest
Re: Monahan Heron
Reply #4 on:
August 17, 2009, 01:33:50 pm »
Ok thanks guys. So if the Forest Steam pressure regulator is expensive, do you know a better / cheaper option?
Bernhard
Guest
Re: Monahan Heron
Reply #5 on:
August 17, 2009, 01:36:25 pm »
Hi......yes..bot Hemmens cost 50£,,,,I DID HAVE 2 ,I HAVE TO SEND BACK,,they didnt work,,, i got the payment back,,,bot ,John Hemmens ..have made some new ones now,,,there scut be working with no problems
Regards Bernhard
Bunkerbarge
Guest
Re: Monahan Heron
Reply #6 on:
August 18, 2009, 09:35:10 am »
These people may be worth communicating with, they do a range of gas control valves that I have heard good things about.
http://fabrice.bretagne.club.fr/Les%20Accessoires%20vapeur.htm
Also Monahan use attenuators in thier steam plants so it is well worth sending an e-mail to Nick.
http://www.monahansteammodels.com/
kno3
Guest
Re: Monahan Heron
Reply #7 on:
August 18, 2009, 11:01:30 am »
I can't find any gas regulators on Monahan's site...
The ones fron Anton look very nice, I might get one of those.
I'm still not sure if a simple unit is sufficient and how much better the double valve unit is?
Bunkerbarge
Guest
Re: Monahan Heron
Reply #8 on:
August 18, 2009, 01:16:57 pm »
There are no attenuators on Monahan's site. He uses them in his supplied plants though so he is obviously worth communicating with.
I use an old Cheddar gas pressure regulating valve to stabilise the pressure in conjunction with an electronic boiler pressure regulating vale which works extreemly well. The electronic type of regulating valve is available from Stuart nowadays and is exactly the same unit as the old Cheddar one.
kno3
Guest
Re: Monahan Heron
Reply #9 on:
August 18, 2009, 06:23:11 pm »
Thanks. I prefer the mechanical one though. I'm trying to keep electronics out of my engines, as far as possible (except for r/c, of course).
Now I just have to figure out which type of gas regulator I should get, and it seems more complicated than I thought, will all the possibilities out there
Print
Pages: [
1
Go Up
« previous
next »
Steam
Monahan Heron
