Author Topic: Stuart engine  (Read 4047 times)
Sailmaker
Stuart engine
« on: August 20, 2009, 12:22:56 pm »
I bought the Stuart engine and center flue boiler in the 1970s for a tug project but due to circumstances it never got off the ground.
I notice that these engines are now quite valuable, this one has only run for a few minutes since I got it.
It seems silly not to use it so what would be the best model/size to put it in.
Thanks.
Re: Stuart engine
« Reply #1 on: August 20, 2009, 02:07:00 pm »
I'm guessing its the 10v (3/4 bore and stroke) it would suit a launch hull around 4 ft long and would push it along nicely.  :-))
Proteus
Re: Stuart engine
« Reply #2 on: August 20, 2009, 02:09:13 pm »
Unless the fittings on the boiler are very big , the boiler looks on the small side have you got any dimensions for  it.? look's like it has a mechanical oiler as well, that is handy
Proteus
Sailmaker
Re: Stuart engine
« Reply #3 on: August 20, 2009, 02:45:13 pm »
The boiler is 165mm long and 90mm wide and was sold as a compatible pair when bought direct from Stuart Turner in 1964. So it's 45 years old now.
The picture has been resized to fit the site and lost it's scale.
I added the mechanical oiler later.
It seems that the grub screw on the eccentric has come loose and the engine has lost it's timing so i need so find out how to re-time the stroke.
Are there any commercial kits that are suitable for it.
gondolier88
  • www.coniston-regatta.co.uk
    • Coniston Regatta
Re: Stuart engine
« Reply #4 on: August 20, 2009, 04:55:13 pm »
Hi Sailmaker,
Lovely little plant the 10V- three things to point out-
1- The safety valve on the boiler is a fantastic, however it HAS to be serviced- it is covered in grime and will need the springs replacing, possibly new ball too.
2- The engine will need the reversing kit to be used in a boat, failing that a reversing gearbox on the propshaft.
3- Timing diagrams are available to download off ST's website.
Look forward to seeing it in a lovely open launch so we can see that lovely engine... :-))
Greg
