Author Topic: 2.4 Ghz Radio  (Read 3099 times)
WingRider
2.4 Ghz Radio
« on: August 25, 2009, 01:23:24 am »
Has anyone had any experience with one of these, or ever heard of them?
http://www.r2hobbies.com/proddetail.php?prod=rcps61207#
Doesn't seem you can beat the price :o
Robert Davies
Re: 2.4 Ghz Radio
« Reply #1 on: August 25, 2009, 02:02:03 am »
I've got the Turnigy badged model. You can control a model way further than you can safely see to control it - if you follow my drift(!)
The programming of the radio is vaguely Hitec-esque.
For the price, well worth a go, and if you can limit yourself to 6 channels, the receivers are silly cheap.
-Rob
ps The radio is also available badged as the Imax 9x - they are all made by FlySkyRC.
WingRider
Re: 2.4 Ghz Radio
« Reply #2 on: August 25, 2009, 02:34:17 am »
Thanks for the info, I may be able to get by with 6 channels. I was concerned about the dirt cheap price, you get what you pay for, you know. I think I'll give them a shot
Robert Davies
Re: 2.4 Ghz Radio
« Reply #3 on: August 25, 2009, 02:39:42 am »
I can only say as I find....
....and I find it to be a good solid reliable radio.
-Rob
barriew
Re: 2.4 Ghz Radio
« Reply #4 on: August 25, 2009, 12:40:42 pm »
It might be worth looking at www.giantcod.co.uk - they have similar models - a 4 and a 6 channel - and the postage is cheaper :o
Barrie
Robert Davies
Re: 2.4 Ghz Radio
« Reply #5 on: August 25, 2009, 01:35:55 pm »
But not to the USA where the OP is from!
-Rob
:D
craftysod
Re: 2.4 Ghz Radio
« Reply #6 on: August 25, 2009, 02:04:31 pm »
Just ordered one from the giantcod site with an extra rx.
wait and see what turns up,only £40 with p+p
Mark
Peterm
  • Inactive
Re: 2.4 Ghz Radio
« Reply #7 on: August 25, 2009, 02:26:46 pm »
Rob,  I have just received my Radiolink 2.4 GHz Tx and Rx`s.   I see there is a small ID SET switch on the side of the Rx.   Since there are no instructions, have you worked out the routine for matching to the Tx, please?   Thanks Pete
I`m not just old, I`m ancient
Robert Davies
Re: 2.4 Ghz Radio
« Reply #8 on: August 25, 2009, 02:35:44 pm »
Try this:
With power to the receiver, press and hold the dinky little switch* on it (the receiver)
Now switch on the transmitter, the receiver LED should change to green, release the DLS* and you should be good to go.
I'm away from all my TX/RX gear at the moment, but that procedure works for 99% of all the Chinese 2.4ghz gear I've tried.
-Rob
Peterm
  • Inactive
Re: 2.4 Ghz Radio
« Reply #9 on: August 25, 2009, 03:15:50 pm »
Rob,   Many thanks,  will try it out tomorrow.  Pete
