Mayhem Facebook
Hi and welcome ajb68,You are venturing into tug towing but you mention a capstan, could you possible be referring to a tow winch?just to make your head spin that little bit faster.R,
Hi ajb68,I have two working capstans on my towboat. I used two large 1/32 scale capstans from Mobile Marine Models. I drilled these out and inserted a 3mm shaft. I then drilled at 90degrees and inserted a pin through the capstan and shaft. The reason for this is easy removal without taking the deck of for future maintenance. The motors i used were two MFA 250/1 geared 12v motors part No 918d.These capstans work fine in fact if I tighten the ropes to much i either snap the 2mm rope or pull other peoples tow bollards off.Hope this helps.Destroyer42
