thanks greggy
its better now, different prop
Dread, my gearbox ratio is 2:1, mfa gears as HS93 has stated. Its not much quicker than direct drive, but way more efficient. With direct drive, it needed water cooling, with the gearbox fitted, motor etc is stone cold, does not need water cooling anymore, run time is better.
Graupner motors, especially the 700 BB Turbo range are purpose made for rc use, and are pretty much bullet proof, providing you dont abuse them like I do
I run 19.2v, volts, for your boat I agree with what HS93 says , you dont want to go as fast as mine, if you have 2 packs and a link cable, then you can use both for fast running, and one at a time for general running, giving you more options
