Author Topic: Pipe Lagging Hovercraft  (Read 6766 times)
andyn
« on: September 18, 2009, 06:59:13 pm »
Come up with a ( or publicize an existing )  simple and endurable plan that modellers can 'have a go at' with
bits of stuff already lying around the workshop.  I seem to remember a kit or plan (SLEC?!?!) that was based on
plywood and foam pipe lagging.......
( The Springer tugs were based around parts from RC cars; 540 motor, 7.2 volts & 2 channel radio, you could do the same! )
  Model Boat Mayhem is here to help you promote your endeavours!
  (PS. Step by step build threads are very popular on here!  :-))
This got me thinking, so I started to build myself a pipe lagging airboat. This is so simple to do, I cut a piece of hardboard to size, which I will glass over later, cut some pipe lagging to size and I was away. The motor mounts were from a 13 foot sailplane that I've never actually fitted a motor to. The engine rails are 1/16" ally right angle, the engine bolts directly on.
Not being of the electric persuation, I'm powering it with an old Irvine 15 buggy motor. I was given it some time back and never run it, though it looks as it it's only just been run in, no grime on it anywhere. If you fancy having a go at one, you could power it with an electric motor of about 600 - 700 size. The engine hasn't been run in ages, but it was stored with oil in it, after I cleared it, I stored it with after run oil. I fitted an O.S remote needle, to keep fingers out the prop. This afternoon, I fueled it up, blasted all the oil out with the starter, connecter the glow start and wheeeeee......
Next up is resining the hull and the engine pod, trimming the piping, then building a radio box :-))
Here it is at the moment
Re: Pipe Lagging Hovercraft
« Reply #1 on: September 18, 2009, 07:03:27 pm »
  :o  We're impressed Andy!!!! :o
     All you need is a bit of ducking ducting under the prop and you do have a hovercraft!
andyn
« Reply #2 on: September 18, 2009, 07:55:08 pm »
Thanks Martin, why not have a go too, you must have an engine sitting around somewhere ;)
I'm going to steal the rudders from a Wot4 kit I never got round to, look plenty big enough O0
Bill D203
  • not long now!!
« Reply #3 on: September 19, 2009, 04:54:12 pm »
Nice one Andy????? But WHY????  {-) {-)
OK bring it down the lake next week and lets see how it goes. Don't forget round mine at 8 Sunday morn . OMRA fun day out at MK.
andyn
« Reply #4 on: September 19, 2009, 08:26:38 pm »
Read the first bit Bill ;)
It's made entirely out of bits I got from boxes etc in the loft. I've yet to buy some more resin, soon as I do it'll gor for some trials. It's had some bath trials already but if I don't glass it the wood will fall apart...
« Reply #5 on: September 20, 2009, 02:31:25 am »
What kind of glue works on this foam Andy?
andrewh
« Reply #6 on: September 20, 2009, 02:33:09 am »
I won't snitch to the RSPB about the ducking
andrew
« Reply #7 on: September 20, 2009, 07:29:42 am »
Well spotted Andrew!  :embarrassed:
 DickyD or Doug99 usually pull-me-up on spelling!
martno1fan
« Reply #8 on: September 21, 2009, 11:15:45 am »
Andy having built and ran airboats a few times in the past id suggest angling the prop up a tad so it keeps the nose down,also when running dont let off the throttle to quick or she will flip.I used to make mine from corroplast and used silicone for glue ok2.Mine was powered by an os 46 ,lots of power and fast as  :o but did like to flip if i let off the throttle too quick.Great fun on water snow and ice  :-)),even damp grass hehe.
Mart
andyn
« Reply #9 on: September 21, 2009, 03:48:44 pm »
If you look veerrryy carefully you'll se that I have done that :-))
Should be good fun on the ice in the winter O0
martno1fan
« Reply #10 on: September 21, 2009, 06:58:21 pm »
Andy i see the prop angled so the thrust is aiming up which will cause the bows to lift ok2 you want the nosecone pointing up in the air so the prop blast is aimed down to push the bow down ,2% angle is enough.Theres a good airboat section on rcu if you wanna check it out :-)).
Mart
http://www.rcuniverse.com/forum/forumid_246/tt.htm
also checkout this free plan they run great.Theres also a  great forum on his site too ,he makes some of the best nitro and gas powered airboats going.Sells kits too i believe.
http://www.cajungatorairboats.com/id11.html
notice the angle he has his prop at  ;)
http://www.youtube.com/watch?v=RNX3gkPAnGA
martno1fan
« Reply #11 on: September 21, 2009, 07:09:58 pm »
I found a new project for my strimmer motors  :-)).
http://www.youtube.com/watch?v=kUVAhTYmHAI&feature=related
chingdevil
« Reply #12 on: September 25, 2009, 09:22:47 pm »
Andy
How are you going to make this airboat into a hovercraft?
brian
andyn
« Reply #13 on: September 25, 2009, 10:20:32 pm »
By... erm... throwing it?
