Author Topic: radio aerial fitting  (Read 4634 times)
hopeitfloats
« on: September 28, 2009, 11:15:15 am »
what are you guys thoughts on mounting radio aerials. i would like to mount it inside a fibreglass hull but not sure whether that may block or partly block the transmitter signals. {:-{
westcoaster
Re: radio aerial fitting
« Reply #1 on: September 28, 2009, 11:26:17 am »
The aerials on my boats are fixed around the hull just below deck level. I thread the aerial through short lengths of plastic tubing glued to the fibreglass. That way if you need to take the aerial out again you can pull in a length of cord with it and re-installation is easy. I've never had any problems with range at all. HTH, Douglas
« Reply #2 on: September 28, 2009, 11:26:55 am »
Fibreglass is transparent to radio.  Just keep the aerial above water level, as water is not completely transparent.
« Reply #3 on: September 28, 2009, 11:28:53 am »
All my receiver cables are mounted around the inside face of my coamings, passed through short lengths of tube.
Signal is OK for as far as I need it. ie boat to far away to see almost. :-))
6705russell
« Reply #4 on: September 28, 2009, 11:36:05 am »
I have only one boat/tug left on 40mhz now and the aerial was always routed around the coaming abover water level obviously, it as been like like that for the last twelve months up until yesterday when it started to cut in and out? Re-routed the aerial so it travels up the main mast and now works fine again, did a range check with the transmitter aerial down and it was fine?
My only thought is that there is some overwhelming signal from something/somewhere that interferes as i am the only one on that frequency?
Russ
Seaspray
« Reply #5 on: September 28, 2009, 11:48:52 am »
hopeitfloats   I try and keep the Rx away from all the other running items in the boat. Ariel cable straight up to below the deck ( as mentioned above water level) and carry on in a straight line done the side of the boat. Also can go up the way if you wish. Its a case of getting as much ariel to pick up the singal form the Tx as possible.
6705russell   Are you saying you have radio problems on the water at a distance ?
hopeitfloats
« Reply #6 on: September 28, 2009, 12:07:47 pm »
thank you all. i was going to do as westcoater said and thread it through a plastic tube under the deck. may seem a dumb question but would the radio make/model be likely to have any effect, as in do some makes perform better than others in this situation. my set is a futaba 4EX-FM.
« Reply #7 on: September 28, 2009, 12:11:12 pm »
Mine are all Futaba, no bother. :-))
6705russell
« Reply #8 on: September 28, 2009, 12:50:58 pm »
Seaspray,
It started  to do it when it was only 5-6 metres from the jetty, strange because i have never had any problems before, i know a couple of the other members have a spot of trouble in a certain area of the lake about 10 metres out, like theres a dead spot?
Russ
hopeitfloats
« Reply #9 on: September 28, 2009, 01:02:11 pm »
thanks dickyd. i was hoping that would be the answer :}
Seaspray
« Reply #10 on: September 28, 2009, 01:55:45 pm »
Hi Russ
If everybody is getting the same problem in that given area(s). It  could be as you suggested a dead spot.
You could prove the point by  moving your position on the edge of the water say up or down 10 yards if possable ( transmit from a different angle. The biggest problem.  I've found on radio failure is dead or bad batteries even the rechargeable ones, and connections. A top to toe inspection is always worth it.
I have Futaba radios too. 27 and 40 MHz no prob except when the time I forgot to put up the ariel on the Tx. Got 12 feet from the bank and panicked. Just remember this, I had intermittent radio failure due to Maplin rechargeable batteries. The top positive connection on these batteries is shorter than Ross's batteries and the maplin one were moving in the Tx which caused a gap between the contacts on the Tx and the battery
hopeitfloats Sorry 4 highjacking the thread.
Rex Hunt
« Reply #11 on: September 28, 2009, 03:36:51 pm »
Could also be in a spot where reflected signals cancel incident signals travelling direct to the aerial.........
A small movement along the bank would nullify this.
Rex
Seaspray
« Reply #12 on: September 28, 2009, 04:08:24 pm »
That as well.
Page created in 0.258 seconds with 18 queries.
