Ok I'm new to this site, and I just have a few questions I wondered if the community might be able to answer and help me with?
I'll just go over them in brief quickly to give people the jist of it all.
1) how do i wire two motors through one ESC?
2) looking at getting 2 of this motor
Graupner Speed 700 Turbo 9.6V (3308)
Particularly suitable for powerful drive systems of sport model boats of from 7 through 10 cells.
Motor with 5-pole armature, drive shaft diameter 5 mm. Stator ring is standard equipment.
Nominal voltage 9.6 V, Operating voltage range 4.8-14,4V
No-load rpm 15000, Current drain at max. efficiency 12.5A
but what does all that about the voltage and amp usage mean to the more simple amoungst us? (me) as I had thought of putting in a 12v lead acid battery.
I have built a boat before, but it was a while back and with my fathers help, and he's an electrical engineer so he knew what he was doing.
Attached should be a couple of pictures of the hull I've been supplied by a friend.
thanks in advance to anyone who can assist with this
