August 14, 2025, 06:17:11 am
Welcome,
Guest
Please
login
or
register
1 Hour
1 Day
1 Week
1 Month
Forever
News:
Home
Help
Search
Calendar
Login
Register
Technical, Techniques, Hints, and Tips
Radio Equipment
Receiver voltage
« previous
next »
Pages: [
1
Go Down
Print
Author
Topic: Receiver voltage (Read 1995 times)
Robs
Guest
Receiver voltage
on:
November 14, 2009, 08:52:51 pm »
Hi y'all, probably a silly question but can I use a 7.2v battery pack with a 6v receiver with BEC? I want to keep weight low and use the power battery for the motor to run the rx. Cheers, Rob
Full Mayhemer
Offline
www.srcmbc.org.uk
Southampton UK
Re: Receiver voltage
Reply #1 on:
November 14, 2009, 09:01:26 pm »
If your speed controller has a BEC and you use it the answer is yes.
Richard
Solent Radio Controlled Model Boat Club
http://www.srcmbc.org.uk
knoby
Guest
Reply #2 on:
November 14, 2009, 11:03:44 pm »
Hi Robs.
If your receiver has a bec circuit built in theres no problem, if not as Dicky says you can use an esc with a bec built in. Alternatively you can use a separate bec circuit.
cheers Glenn
Robs
Guest
Reply #3 on:
November 16, 2009, 11:04:16 am »
Thanks guys, I can get on with the build now. Cheers, Rob
Print
Pages: [
1
Go Up
« previous
next »
Radio Equipment
Receiver voltage
