Author Topic: grease  (Read 4317 times)
new start
grease
« on: November 30, 2006, 09:29:02 pm »
can anyone recommend a suitable grease for my schottel drive units for the gears and shafts also where can i get some.
derek
Re: grease
« Reply #1 on: November 30, 2006, 11:44:53 pm »
You might like to visit your local garage workshops.
I was chatting to the man in mine and explained that I was building a model boat and he gave me a free 'scoop' of 'water pump'  grease.  Obviously designed to get wet.    ;D
Cheers...Ken
HS93 (RIP)
  • I cannot spell , tough
Re: grease
« Reply #2 on: November 30, 2006, 11:49:56 pm »
As there are plastic gears you have to watch they are not melted. try looking at tamya model car  products as they are designed for the purpose. Peter
White Ensign
  • Limits must be limited!
Re: grease
« Reply #3 on: December 11, 2006, 11:19:11 am »
The best is a grease with teflon, if there are plastic-gears inside. But just a reasonable quantity as the grease otherwise can harm the bearings (depending on the pressure on the gears).
Another excellent stuff is thick Silicone-oil.
Jörg
When God created planet earth, he made it with 75% of water. Bet he had the modelboaters on his mind!
cbr900
  • Mayhem is the Only Forum!
    • Roys Hompage
Re: grease
« Reply #4 on: December 11, 2006, 11:59:09 am »
I use wheel bearing grease in my schottel drives, and have not yet had a drive gear fail, four of the units are now over twenty years old and work perfectly......
Roy
White Ensign
Re: grease
« Reply #5 on: December 11, 2006, 11:26:08 pm »
Roy, every bird sings his own song- as long as it works, everything`s fine   :D
Jörg
P.S.: One question could lead to 100 solutions....
Re: grease
« Reply #6 on: December 12, 2006, 08:28:27 am »
Robbe do a grease made for what you want it for. Its called shaft lubricant. :)
Richard 8)
