Author Topic: Battery Connector Question  (Read 2874 times)
darthu812
« on: December 05, 2009, 02:48:03 pm »
I bought a new 6V lead acid battery for my model boat. Then later i realised that the connector from the ESC was a tamiya plug, so this cannot connect into the two (possitive and negative) ports on the battery. I looked around the net to see if there was a cable which had a tamiya socket on one end and two spade connectors on the other but i couldn't find one. Could anyone give me any advice on how to overcome this problem or is it easier to buy a NiMH power pack which already has the connect tamiya socket?
cheers
Bradley
Re: Battery Connector Question
« Reply #1 on: December 05, 2009, 03:10:29 pm »
I think that the easiest way is to get a Tamiya plug with leads already attached (eBay? or your local model shop) and then get a couple of the appropriate size connectors from Halfords (or any car accessory shop) clamp them on securely and away you go.  :-))
Derek.
boatmadman
« Reply #2 on: December 05, 2009, 03:11:18 pm »
You have a couple of options, one is as you say, buy a battery with connector already fitted.
The cheaper option seeing as you already have a battery is to cut off the tamiya connection and replace with an alternate pair - one on battery, one on cable.
Use a couple of banana plus/sockets, if you have any around, just make sure they have the load cpacity you need.
Ian
riggers24
  • Just full of stupid questions
« Reply #3 on: December 05, 2009, 03:30:04 pm »
Check out the component shop for leads and connectors
I will finish the crash tender someday - Still got tooo many toys to play with
« Reply #4 on: December 05, 2009, 03:58:11 pm »
« Reply #5 on: December 05, 2009, 07:21:19 pm »
I'm with Derek. Did exactly as he suggests years ago, no problems since (apart from leaving the lead on the shelf when I went to the pond  :embarrassed: )
Page created in 0.233 seconds with 18 queries.
