Hi everyone
this is typical of me, I have drilled the keel of my schooner to take a 6.5"long x .250" dia brass prop shaft with a m4 spindle, I will be attaching a 1.1/2"dia prop, which is not a problem, what is a problem is the other end, I have just 4" to house the motor and the universal joint, but now I am told I will also need plain/threaded couplings as well.
The motor I will be using is a Mabuchi RS540 whilst it gives me the Dia of the motor and shaft dia it does not state the length, the same goes for the universal joint and the couplings
My question to anyone who has used this set up is ,will the motor, the joint and couplings fit in a 4" space between the bulkhead and the threaded end of the shaft ?
And does the coupling slide into the universal joint to take up end float and if so how much do I allow for, I'm sorry if I sound dim, but I am reluctant to start buying without understanding what is involved
regards Geoff
