Author Topic: PS Glen Sannox - build thread  (Read 18164 times)
snowwolflair
« on: March 16, 2010, 10:35:25 am »
I normally build warships and post on the ModelwarshipUK site.  My latest build is a Clyde paddle steamer and as I have had several requests to see the build I am going to post the build thread here.  If anyone has any questions please post them and I will try to answer.
snowwolflair
Re: PS Glen Sannox - build thread
« Reply #1 on: March 21, 2010, 10:27:45 pm »
A few more shots showing the construction of the floats/seats.  A bit fiddly but the end result looks the part.
Peewee
    • Paddleducks
« Reply #2 on: March 27, 2010, 11:24:29 pm »
looking good.
peewee from modelwarshipuk
Ian
Still sane? who knows who cares?
snowwolflair
« Reply #3 on: May 01, 2010, 07:32:05 pm »
Finally the railings.
More Coffee
« Reply #4 on: May 01, 2010, 07:37:56 pm »
My gawd thats well done..
snowwolflair
« Reply #5 on: May 02, 2010, 12:57:51 pm »
Thank you very much :-)
snowwolflair
« Reply #6 on: May 03, 2010, 08:04:55 pm »
A few more shots of the railings.
Peewee
    • Paddleducks
« Reply #7 on: May 03, 2010, 08:59:29 pm »
fantastic looking build, i look forward to the next installment.  :-))
Ian
snowwolflair
« Reply #8 on: May 07, 2010, 08:03:49 pm »
Railings now complete
« Reply #9 on: May 07, 2010, 10:10:52 pm »
What a lovely job you've made of them. Well done.     :-))
Ken
snowwolflair
« Reply #10 on: May 07, 2010, 10:41:31 pm »
Thank you.  Seeing double tonight after focusing on them.
I need to cast the Cowls next
« Reply #11 on: May 07, 2010, 11:13:36 pm »
     :o...... how much did that cost?
snowwolflair
« Reply #12 on: May 07, 2010, 11:47:42 pm »
It works out about 45p a stantion including the brass rod, but it is worth it.
snowwolflair
« Reply #13 on: May 08, 2010, 12:23:43 am »
Cowl casting under way.  The master is a lash up of tube and a plastic cowl top that was close to the required shape.  A bit of green stuff and a lot of filing  and a reasonable result was achieved.
the moulding compound is the two part material available in most art/craft stores these days.  I mould it as a big solid lump round the master with a flat end so it sits up the correct way.  I then cut it with a sharp scalpel down one side to release the master.  I hold the mould tight closed with rubber bands.
« Reply #14 on: May 08, 2010, 04:02:25 am »
 snowwolflair ...you should link your build thread up with Paddleducks    www.paddleducks.co.uk    ...the largest & only WEB site dedicated to paddlers .......the members would enjoy your work   O0
BTW....your brass railing work is  :-)) ....how have you secured each stanchion to the deck?........ %% Derek
snowwolflair
« Reply #15 on: May 08, 2010, 03:11:51 pm »
The stantions have a 1mm spike on their base that goes into an drilled hole on the deck.  I then use the very thin superglue and run it into the joint.  The stantions had to be drilled on top to add a further 5mm of brass rod to mount the wooden railing.
snowwolflair
« Reply #16 on: May 09, 2010, 11:56:30 pm »
Deck mats and cowls placed but not yet fixed.  The mats are cut by laser.
snowwolflair
« Reply #17 on: May 15, 2010, 11:33:04 pm »
Funnels painted.
snowwolflair
« Reply #18 on: June 13, 2010, 11:08:20 am »
Progress, with the railings complete and painted.  I am now touching up the paintwork on the hull and I will add the remaining lining in the next few days.
snowwolflair
« Reply #19 on: July 18, 2010, 10:46:58 pm »
On the water
marinemole
« Reply #20 on: July 19, 2010, 10:15:56 am »
Beautiful looking ship and an equally beautiful model. Green with envy.
Andy
Perkasaman2
« Reply #21 on: July 19, 2010, 10:39:05 am »
Beautiful work!  :}
snowwolflair
« Reply #22 on: July 20, 2010, 12:50:02 am »
Thank you, I hope to have here complete in the next few months. She needs boats and davits and a lot of small details.
After that I have 130 passengers to paint!  Thats a long winters night task.
gondolier88
  • www.coniston-regatta.co.uk
    • Coniston Regatta
« Reply #23 on: July 20, 2010, 05:49:34 pm »
She's stunning, well done.
I look forward to seeing all those passengers...
Greg
Edward Pinniger
    • Plastic Ship Kit Previews
« Reply #24 on: July 24, 2010, 01:01:17 pm »
Looks like a seriously impressive model  :-)) - great work! Not sure how I missed this build thread, didn't spot it until a few days ago or I'd have posted earlier.
Are the on-water photos taken at Black Park?
Page created in 0.848 seconds with 18 queries.
