Author Topic: pumps  (Read 2799 times)
me3
pumps
« on: April 10, 2010, 06:45:34 pm »
Hi all
Does anyone know where i can get a water pump that will run on 14.4 volts.
regards Reece.
Re: pumps
« Reply #1 on: April 10, 2010, 07:07:52 pm »
What capacity, flow rate, physical size etc?
Re: pumps
« Reply #2 on: April 10, 2010, 07:12:18 pm »
if you can't find a 14.4v pump, you might want to think about a voltage regulator circuit... or a couple of diodes to
drop the voltage down to 12v, lots of 12v 'car windscreen washer' pumps around.... I bet most 12v pumps will
be OK on 14.4v... might be a bit exuberant!
me3
Re: pumps
« Reply #3 on: April 10, 2010, 07:18:45 pm »
Thank you very much for your information. I shall be down the dump tomorrow trying to find a windscreen washer pump. I would like to  use the pump to have water coming out of the exhausts of my Lifeboat.
Regards Reece
 8) :}
Re: pumps
« Reply #4 on: April 10, 2010, 07:34:54 pm »
Why not use simple water scoops on the underside of the model.
This will  change output with speed.
me3
Re: pumps
« Reply #5 on: April 10, 2010, 08:10:27 pm »
OOO...
Sorry i am new to the modeling world as i only started at Christmas.
Thanks for all your information
Regards Reece
HS93 (RIP)
  • I cannot spell , tough
Re: pumps
« Reply #6 on: April 10, 2010, 10:04:13 pm »
if you use a car pump for just that you want to run it on as low a voltage as you can get it to pump on , if not instead of a splutter of water it Will be a spray jet and the washer pumps are very noisy running flat out, you could try a wagon 24v one they have them exactly the same sizes and capaceties as car ones, or put a bulb in series of the 12v one that will slow it down and quieten it you could also put a coil around the motor and cool that as  well before going out the back.
Peter
Prophet
Re: pumps
« Reply #7 on: April 26, 2010, 02:06:06 am »
haha i just did a post on pumps too...
http://www.modelboatmayhem.co.uk/forum/index.php?topic=23662.0
hope it helps   :-))
More Coffee
Re: pumps
« Reply #8 on: April 26, 2010, 02:24:37 am »
When the vehicle is running and the alternator kick's in ..there should be between 13.6-14.4 volt going to the battery depending on the state of the load on the system ..I have seen 15v+ in a few cases where the battery is run rather low and engine rpm is up..
A washer pump  will have no problem using 14.4 volt ..But remember that the washer pump is designed for intermittent service and will quickly burn out if run on extended cycles of operation ..they are not a duty cycle pump..
I went to a auto parts supplier and got a new 12v universal washer pump for $14 Can. ,had a mount, hose ,and no trying to get a wireharness ..for it had 18" lead's..Which made it easy to intergrate into my harness on the tug
Page created in 0.019 seconds with 18 queries.
