Author Topic: Water cooling inlet pipe position?  (Read 4596 times)
Patrick Henry
« on: April 27, 2010, 04:04:20 pm »
Where's the best place to put the watercooling inlet pipe guys...it states in the destructions that it goes on the port side, but where? Between the prop and the rudder and offset to port? The rudder will be cut down some, by the way...
Ta...
Bill D203
  • not long now!!
Re: Water cooling inlet pipe position?
« Reply #1 on: April 27, 2010, 06:46:11 pm »
Hi Rich
I put mine in between the prop and the rudder in line. However you don't seem to have alot of room. Have fun!!
Patrick Henry
« Reply #2 on: April 27, 2010, 07:12:31 pm »
Mine is now off to one side and angled slightly towards the propwash....fingers crossed Bill.
tobyker
« Reply #3 on: April 27, 2010, 08:23:57 pm »
The most elegant one I've ever seen was in a hollow skeg off which the rudder was hinged.
Patrick Henry
« Reply #4 on: April 27, 2010, 08:26:00 pm »
I guess that would have been on a transom mounted rudder? Mine is a standard submerged set up....
BJ
« Reply #5 on: April 27, 2010, 08:40:35 pm »
You could always use the pickup the the FSRV boats use see http://www.prestwich.ndirect.co.uk/hdwraccs.htm item GA1A virtually above your prop
pompebled
« Reply #6 on: April 29, 2010, 07:18:16 pm »
Here's a variation on the theme:
A pressureless system; the inlet facing forward and the outlet facing towards the transom, creating sucktion.
Position the inlet where the propwash hits the bottom and the outlet away from the wash.
Keep the tubing inside the hull as low as possible and, once the tubes have filled, the flow will continue even at half throttle or less (but who would want that...).
Her's the lay-out inside the hull:
Regards, Jan.
Boaters are nice people
Patrick Henry
« Reply #7 on: April 29, 2010, 07:33:56 pm »
That's a good idea Jan...I like that.
Cheers...
w3bby
« Reply #8 on: May 01, 2010, 03:35:01 pm »
I use a flush inlet as above but prefer to have the outlet on the side or deck so I can see that the cooling is working.
andyn
« Reply #9 on: May 01, 2010, 03:58:08 pm »
Here's the setup I use on my multi, copper tube protrudes just below the bottom of the hull, note it isn't filed flat as it doesn't pick up as much water. The tube bends round inside the hull right the way up to the engine mount where a very short piece of silicon tube connects it to the engine, then on the other side it goes straight out the boat. Despite the fact the tube is only 3/32" inside diameter water absolutely p***** through it.
Patrick Henry
« Reply #10 on: May 01, 2010, 05:35:36 pm »
Off topic slightly, but how's Mervyn..no, Martin..no, Mary.. no, that yellow submersible of yours Andy?
andyn
« Reply #11 on: May 01, 2010, 07:04:27 pm »
Just waiting on some money to buy Melvin some new seals and a failsafe :-))
pompebled
« Reply #12 on: May 05, 2010, 06:54:46 pm »
Now that is a matter of faith; I knów his system works, so I don't need to see the outlet.
Next to that, the point was to have a pressureless cooling loop, that doesn't induce drag...
Regards, Jan.
Page created in 0.576 seconds with 18 queries.
