Author Topic: Trimming - Rough/Smooth Water  (Read 3098 times)
johnukhenry
« on: January 05, 2007, 06:52:55 am »
Can't remember where/which forum i read this, or it might be old age catching up but its the subject of rough water running.
Being a bit of wimp I internet weather watch and only run my larger/faster boat on fairly glass/smooth water as anything too rough makes things TOO exciting if things get hairy without a rescue boat. Does the moving of battary backwards or forwards to 'trim' the boat for rough or smoother waters make any difference. I am used to trimming my aircraft but this is all new to me.
Thanks John
Daryl
Re: Trimming - Rough/Smooth Water
« Reply #1 on: January 05, 2007, 08:56:37 am »
Its common practise in the  FE series of SWAMBC to move the battery around depending on the wave conditions. Needless to say lots of experimintation.
Hope this helps
Daryl
BobF
« Reply #2 on: January 05, 2007, 12:06:39 pm »
Hi johnukhenry,
I have a Dateline Cherokee, and the instructions suggest moving the batteries forwards for calm water and backwards for rough water. I presume this is to stop the boat hooking in rough conditions.
Bridkid
    • Bridlington Model Boat Society
« Reply #3 on: January 05, 2007, 03:53:42 pm »
Hmmm,
well I actually move my cells forward for rough weather to keep the nose down, not a lot I'll grant you, but forward nevertheless. Just one teeny quarter of an inch can make quite a difference.
Trial and error is perhaps the best method, just make sure you aren't too ar away from land when you open up the throttle if you don't have access to a rescue boat! Anyway, racing in rough weather is much more fun!!
Cheers,
Ian. 8)
BobF
« Reply #4 on: January 05, 2007, 05:35:03 pm »
HI IAN,
Trust you to move your batteries the wrong way.  ;D
