Hi All
I was reading Debssnal's excellent post about his new tug(s). He mentions needing prop speed of 950 rpm for max hull speed.
This begged the question. How did he work that out then?
I found these two links. They may be of interest to someone.
[url]http://www.psychosnail.com/BoatSpeedCalculator.aspx/url]
[url]http://books.google.co.uk/books?id=8w09O4hooWUC&pg=PA48&lpg=PA48&dq=propeller+water+slippage+formula&source=bl&ots=AdoHVlmEDY&sig=gE3R-2yfdLNNcK6g_b57f6uMZ5c&hl=en&ei=j2nmS6SNDIvwmwPUiekh&sa=X&oi=book_result&ct=result&resnum=2&ved=0CB4Q6AEwAQ#v=onepage&q&f=false/url]
I typed my boat's data into the hull calculator (semi-displacement type) The results seemed pretty accurate. It told me I needed 212 watts of power, which is about what I have.
What methods do others use? Any mathematicians out there?
Mmm, now how can I squeeze in a kilowatt???
Pete
