Author Topic: Using 1 ESC with Two Motors  (Read 3418 times)
asimmd
« on: May 18, 2010, 08:45:11 pm »
Hi Guys
Is it possible to use 1 ESC with 2 motors and use a "Y" lead to control both
on 1 stick.
Yes I know I should use a mixer but will this work for now?
Alan
Re: Using 1 ESC with Two Motors
« Reply #1 on: May 18, 2010, 09:19:54 pm »
« Reply #2 on: May 18, 2010, 09:20:04 pm »
Yes as long as esc is big enough [amps]
If this is the two Deans Kondor motors, I have them in my Amethyst running off one 20amp Viper speed controller, no bother. :-))
FullLeatherJacket
« Reply #3 on: May 18, 2010, 11:01:55 pm »
Sorry.......one ESC with two motors is OK................but a Y-lead? You would only use a splitter/Y-lead if you had two ESCs from one Rx output.
I think you're after describing something like the top diagram here:
http://www.action-electronics.co.uk/pdfs/Twin%20Motors.pdf
...but I may be wrong........
FLJ
asimmd
« Reply #4 on: May 19, 2010, 09:31:21 am »
Hi All
Thanks for the replies.
I was getting ahead of myself after seeing a report in Marine Modelling mag,and
as usual I got it all wrong.
What I want to do is use 2 motors controlled by 1 ESC,the "Y" lead is of course for
use with 2 ESC.
Had a senior moment,sorry.
Alan
« Reply #5 on: May 19, 2010, 09:47:05 am »
Alan,
There is a minor problem with this as each ESC will start at its own point.
The full speed should be the same but can effect low speed maneuvering.
« Reply #6 on: May 19, 2010, 09:54:45 am »
He only wants one esc Bob  :-))
« Reply #7 on: May 19, 2010, 10:06:53 am »
yes, must be going dafter.
1 ESC will be fine as long as it can handle the combined current.
Flying Sparks
« Reply #8 on: May 19, 2010, 03:47:53 pm »
One esc sould work OK if they are brushed motors. Brushless motors would have a problem with a single esc as the motors may not both start in the correct direction.
Phil.
