Author Topic: tx rx  (Read 4109 times)
regiment
tx rx
« on: May 31, 2010, 04:08:34 pm »
is it possible to use a 6 channel rx 2 channels not working ... with  a 2 channel rx  this is a futuba
Islander1951
Re: tx rx
« Reply #1 on: May 31, 2010, 04:50:21 pm »
6 channel rx is an FM rx
2 channel Tx is AM
 so I don't think that it will work for you.
Note also that Futaba make the 2ch Tx both as 27 and 40 Mhz versions,
and these are not interchangeable, you must have the right crystals in the right Tx
New Rx is not too expensive, and  it's worth spending a little money to be sure that
your pride'njoy doesn't go careering away to end up as a pile of bits.   {:-{   :-))
             Edward.
regiment
Re: tx rx
« Reply #2 on: May 31, 2010, 05:43:57 pm »
thanks for answer
regiment
Re: tx rx
« Reply #3 on: May 31, 2010, 06:30:52 pm »
here again i just found in my spare box a futuba receiver r 152 je  2 channel  40 mhz am  so what is my transmitter it  is a futuba  t2er is it fm or am  cannot see any markings on it  thanks again
Re: tx rx
« Reply #4 on: May 31, 2010, 08:38:11 pm »
If this is your Rx Gordon then it is AM
HS93 (RIP)
  • I cannot spell , tough
Re: tx rx
« Reply #5 on: May 31, 2010, 11:50:16 pm »
must be a big boat to fit that Rx  :embarrassed:
Peter :}
Re: tx rx
« Reply #6 on: June 01, 2010, 07:55:04 am »
Forgive Sir Dicky the Faux Pas
He was so overwhelmed by
his award that he cannot
tell his Tx from his Rx!
Re: tx rx
« Reply #7 on: June 01, 2010, 08:19:48 am »
OK, So I've had a hard weekend %)
regiment
Re: tx rx
« Reply #8 on: June 01, 2010, 08:32:23 am »
thanks dicky thats the one so now a compleate set  would the tx work with a 2 ch zebra rec
Re: tx rx
« Reply #9 on: June 01, 2010, 11:59:25 am »
No you need a Futaba AM receiver.
Re: tx rx
« Reply #10 on: June 01, 2010, 05:15:24 pm »
Try it on the bench, if both are AM then it might work. I regularly use a Futaba Tx and Hitec Rx and vice versa with no problem. FM seems to be more fussy.
Doug
regiment
Re: tx rx
« Reply #11 on: June 01, 2010, 05:55:12 pm »
thank you one and all
Big Ada
Re: tx rx
« Reply #12 on: June 03, 2010, 05:35:49 pm »
I didnt understand the 1st Question. {:-{.
Len.
