Author Topic: prop size  (Read 2672 times)
octo
prop size
« on: June 13, 2010, 10:27:22 am »
good morning everyone; Is a 40mm three bladed prop big enough to
use on  a 36 inch coble, your suggestions please. Thanks tony :-)
Re: prop size
« Reply #1 on: June 13, 2010, 11:20:00 am »
Yes if you spin it fast enough.
I have a 38mm 2 blade prop on a  PT boat and she flies with a stock 540 motor on 7.2 volts.
The problem is that there are so many different pitches for 40mm.
A fine pitch will need rpm to push it along, a coarse pitch will need torque to push the model along.
What is the scale prop size for the model?
octo
Re: prop size
« Reply #2 on: June 13, 2010, 01:21:42 pm »
the motor siize; is speed 600,8.4v, Ive been told this will give me the torque i require.
the scale size im building in is 1/12 scale. Tony
BJ
Re: prop size
« Reply #3 on: June 13, 2010, 07:05:30 pm »
Take your choice from attached list, (it is no longer published) .........
octo
Re: prop size
« Reply #4 on: June 13, 2010, 07:23:33 pm »
 Thanks BJ; :-)) :-)). yours Tony.
Re: prop size
« Reply #5 on: June 13, 2010, 07:29:45 pm »
Tony,
Speed 600 motor:
Graupner Speed 600 7.2v Pt No 1793
Product informationPowerful standard electric motor with high torque. Particularly suitable for direct drive operation on 6 cells.Specification   Nominal voltage 7,2 V Operating voltage range 3,6 ... 8,4 V   No-load rpm 18200 min–1   No-load current drain 2 A   Current drain at max. efficiency 12 A   Current drain when stalled 85 A   Max. efficiency without gearbox 69 %   Length of case, excl. shaft 57 mm   Diameter 35,8 mm   Free shaft length 8,7 mm   Shaft diameter 3,17 mm   Weight   195 g
On 8.4 volts about 20000rpm
That ia an awful lot or rpm for your type of model. That equates to a mild race type motor.
octo
Re: prop size
« Reply #6 on: June 13, 2010, 09:59:50 pm »
bob; Thanks for the update, %) It looks as though ill have to changed the
subject title to "motor and prop sizes  O0, thanks tony
Page created in 0.18 seconds with 17 queries.
