Author Topic: A quickie for you techie types...  (Read 4032 times)
Patrick Henry
« on: June 25, 2010, 11:05:55 am »
Can I use my HiTec Optic 6 tx (40mhz) with a Zebra ZR-106F 5 channel 40mhz receiver?
Subculture
    • Dive-in to Model submarines
Re: A quickie for you techie types...
« Reply #1 on: June 25, 2010, 11:12:29 am »
I would think so, yes.
« Reply #2 on: June 25, 2010, 11:32:02 am »
Assuming they are both FM or both AM the combination should work. I regularly use AM Futaba and Hitec combinations.
HTH
Doug
Patrick Henry
« Reply #3 on: June 25, 2010, 11:34:36 am »
Yep, both the tx and rx are 40mhz FM...think I'll give it a try. Thanks chaps...
« Reply #4 on: June 25, 2010, 11:37:12 am »
Be aware of a possible crystal missmatch and I don't mean only using the same pair of one type.
portside II
  • tugs at rest
« Reply #5 on: June 25, 2010, 07:55:09 pm »
As long as they are the same type eg, 40mhz ,FM and on the same make of xtals you should be ok
Also check weather they are single or dual conversion , you must use the correct xtals ,
if you are unsure check it in the workshop first and then do a range check just for piece of mind .
daz
Mi Amigo
« Reply #6 on: June 25, 2010, 08:08:29 pm »
In my experience when mixing and matching tx's and rx's, each unit has to be using it's own makers specified, (or compatable), crystal.
For instance the Zebra receiver may need a Zebra crystal installed to match the frequency of the Hitec Transmitter with a Hitec crystal installed.
Of course the crystals must be matching frequencies even though the are made by different manufacturers.
All the best
The long Build
« Reply #7 on: June 25, 2010, 08:48:39 pm »
I have never had a problem when borrowing someones crystals.
portside II
  • tugs at rest
« Reply #8 on: June 25, 2010, 11:04:42 pm »
I think this crystal buisness may have stemed from the early set-up's , where they were fussy and using crystals from different manufacturers was frowned upon in the aricraft fraternaty where any faliure could be possibly fatal.
Nowadys i think its safe to mix and match as long as you test first , the last thing we want is a springer on the loose  %% .
daz
play safe
Patrick Henry
« Reply #9 on: June 27, 2010, 10:16:56 am »
Just for your information guys, a 40mhz Zebra 5ch rx works perfectly well with a 40mhz HiTec Optic 6 tx.
Thanks,
« Reply #10 on: June 27, 2010, 10:58:10 am »
Should start a pick and mix crystal table, another possibility was that the original radio manufacturers like Fubar didn't want to risk loosing revenue by customers buying cheaper sets. We used to go through the same thing with mix and match servos for the centre point and either side limits --- Fubar again.
FullLeatherJacket
« Reply #11 on: June 27, 2010, 11:30:24 am »
"Fubar"??
Patrick Henry
« Reply #12 on: June 27, 2010, 11:44:44 am »
Cheap version of Futaba boss...don't you know nuffink?
« Reply #13 on: June 27, 2010, 12:41:24 pm »
Was going to write Fubarter FLJ.
barriew
« Reply #14 on: June 27, 2010, 01:06:28 pm »
daz
play safe
When I had both Hitec and Futaba 40mhz sets, there was definitely an incompatibility. Checking with a frequency scanner, some combinations of crystals would span more then one frequency slot. I first noticed the problem whilst sailing, then did a comprehensive check using the scanner.
Sorry - I no longer have the table I created.
Barrie
Page created in 0.026 seconds with 17 queries.
