Author Topic: engine gurues help please  (Read 3617 times)
gwa84
« on: June 30, 2010, 08:29:43 pm »
hi all i have a super tigre serie x 40g glo engine and ime trying to fined a manual for it as well as desperately trying to fined out what thread size the main shaft is so i can buy a coupling for it if anybody can help it would be most appreciated thanks mayhemers
Re: engine gurues help please
« Reply #1 on: June 30, 2010, 09:17:49 pm »
Most older engine shafts are 1/4 UNF
Not the same engine but the basics are the same.....
 http://manuals.hobbico.com/sup/sup-manual-v1_1.pdf
Ian Robins
« Reply #2 on: June 30, 2010, 09:50:18 pm »
hi,
could also be m6.
ro88o0
StevenageMBC
« Reply #3 on: June 30, 2010, 11:11:04 pm »
I doubt highly that even if you could find a manual that it'd be in there. Best thing to do is get the calipers or even ruler out and measure it. After you've done so, give your favorite shop a ring and tell them what you need and what it's for. You'll also be needing a flywheel for it.
Dueller
« Reply #4 on: June 30, 2010, 11:53:38 pm »
Being made in Italy i would think that the shaft would be metric, maybe a 5 or 6mm
CGAux26
« Reply #5 on: July 01, 2010, 04:45:54 am »
If you have a thread gauge and a digital caliper or a small dial micrometer you can find the shaft diameter and thread pitch.  If not, take the crankshaft (or the whole engine) to your local hardware store, to the nuts-and-bolts aisle.  Try different nuts until you find the size that fits.
Or you can buy a nut and bolt identifier from Lee Valley tools (US & Canada).
http://www.leevalley.com/US/hardware/page.aspx?p=64800&cat=3,41306
It's nice to see an old Super Tigre, with a tubing fitting installed to pressurize a fuel tank.  I have not seen one since I was a teenager in the '60's.  A hot engine.
gwa84
« Reply #6 on: July 01, 2010, 12:02:04 pm »
thanks guys for the help
ye its a very nice moter loads of compression ive run it up on a airo prop and she performed very well and i have a flywheel all ready for it
triumphjon
« Reply #7 on: July 01, 2010, 10:21:02 pm »
had a super tiger many years ago , 40 sized front induction /rear exhaust  with abc piston & liner , went like an absoulute rocket ! as for couplings i always used dave at prestwich models , specilise in racing parts etc for ic models , very good service too !
