Author Topic: ANGLE OF FINAL SHAFT  (Read 1737 times)
rathikrishna
« on: August 07, 2010, 07:04:05 am »
Helloo...Members..i have a doubt to clear with you all..is will you suggest me about the angle of prop shaft with respect to a parellel line in 90 degree..?  if i made it too steap,what will happen..?  will it drive forward..?  or loss..?  please...
Bunkerbarge
Re: ANGLE OF FINAL SHAFT
« Reply #1 on: August 07, 2010, 07:33:06 am »
If you are referring to the angle of the propshaft and propeller then making it too steep is simply wasting energy.  Try to keep it as level as possible to make sure that all the generated thrust is driving the boat forward rather than trying to lift it out of the water.
rathikrishna
« Reply #2 on: August 09, 2010, 08:15:54 am »
thank you sir...thanks for the advice...i asked because of my inexperience in R/C water based crafts...sure i made a CLYDE PUFFER, a 3 feet long, is driven by a heavy motor,taken out from a car wiper assy, its powerfull.but when i start the controls,it propels foreward,but soon it drops its nose down, and the same attitude increases as it runs fast...but it stabilises when i releases my finger from control..yes its drive shaft is too steep, as to save space for a heavy battery...i hope its prob may due to the high angle of prop shaft...so now i can change it... thanks once again...and expecting more advices....have a nice day....
Page created in 0.295 seconds with 15 queries.
