Author Topic: Soldering pipework  (Read 3705 times)
MichaelK
Soldering pipework
« on: August 07, 2010, 07:49:02 am »
Just a quick question, is a small butane powered burner (Bernzomatic brand, about the size of 3 subC batteries) hot enough to silver solder pipework on a model steam plant?
Thank you
Mick
boatmadman
Re: Soldering pipework
« Reply #1 on: August 07, 2010, 08:20:04 am »
Mick,
Whilst the flame temp will be hot enough, the limiting factor will be the rate at which heat can be applied to the pipe v heat transfer away from the joint area. You might struggle with that small burner.
I would suggest using a bigger torch, it will make the job easier and quicker.
MichaelK
« Reply #2 on: August 07, 2010, 08:51:50 am »
Thanks Ian,
Back to the toy shop\hardware shop I suppose.  {:-{
The little burner is great for small jobs ;)
Mick
kiwimodeller
« Reply #3 on: August 07, 2010, 10:08:40 am »
I find that a small torch like that is fine for soldering on small items such as fittings on the end of tubes but it does not put out a big enough "quantity" of heat to heat up large objects.  Try and hold whatever you are soldering in something which does not conduct heat away. In summary, it will be useful but you will need a bigger one to solder large objects. Cheers, Ian.
Page created in 0.293 seconds with 17 queries.
