I have just completed a hard chine hull, it all seems to be well jointed but when placed in the bath with a rubber duckie there is a small amount of water getting in. It is not coming through anything obvious, ie. prop shaft etc. I guess there must be a bad joint even though I can't see one. Questions:
1) when you talk about sealing a hull, do you mean sealing the wood against water damage as you would a window frame (by painting it) or do you mean preventing leaks?
2) I have read lots of you use Z Poxy - again, does this cure leaks or just prevent water damage?
3) Could the hull be coated with tissue and dope?
4) this particular boat will be painted, but what would you do on a boat which had been built plank on frame and you wanted to maintain a natural look?
Please excuse my lack of knowledge and many thanks for any help.
