Pages: 1 2 [3]   Go Down
Author Topic: FSB tenby  (Read 18559 times)
Number 6
Re: FSB tenby
« Reply #50 on: January 23, 2011, 05:08:48 pm »
Just wondering where to buy the red and yellow stripe from for around the edge?, does this come as one or two seperate stips?
Thanks, Ben :D
Hi Ben, I get mine from Barry's Model Lettering. Lots of different width stripes on one long sheet, very useful. Cheers, Dave.  :-))
Coachlining                       http://www.modellettering.com/showProducts.asp?categorycode=05
Lifeboat Livery Sets           http://www.modellettering.com/catDetail.asp?categorycode=09
1/32 Tenby Tamar Livery   http://www.modellettering.com/prodetail.asp?productid=308&categorycode=09
Homepage                       http://www.modellettering.com/index.asp
Ben Tickle
Re: FSB tenby
« Reply #51 on: February 03, 2011, 09:40:45 pm »
Sorry to mither you all again,has anyone evr had a servo go in an FSB tenby. I only ask because mine is under the part of the deck at the rear of the cab?
Ben
Number 6
Re: FSB tenby
« Reply #52 on: February 03, 2011, 09:54:12 pm »
I'll guess you can't get at it? Can you fit another servo further forward and make a new linkage? Easier than trying get under the deck, unless you can cut a section out and make it look like the door used to access the rib? Dave.
justgiving.com/lochnessscalesail
Ben Tickle
Re: FSB tenby
« Reply #53 on: February 03, 2011, 10:05:58 pm »
Hi Dave,
I could use epoxy to glue the deck to the hull so that this can be removd if necessary. Alternatively i could alter the positioning of the tray. I could also, have a seperate piece of wood etc that slots into place, which can be removed but has the servo on.
Ben :-))
Ben Tickle
Re: FSB tenby
« Reply #54 on: February 15, 2011, 09:29:40 pm »
Hi All,
I have finally completed my Tenby, i have changed the rear rail.
Thanks %%
Number 6
Re: FSB tenby
« Reply #55 on: February 16, 2011, 07:16:28 am »
You'll have to post some pictures so we can have a look, Dave.  :-)) :-))
Pages: 1 2 [3]   Go Up
Page created in 0.7 seconds with 18 queries.
