Pages: 1 [2] 3   Go Down
Author Topic: FSB tenby  (Read 18548 times)
triumphjon
Re: FSB tenby
« Reply #25 on: January 05, 2011, 09:20:27 pm »
larry the angle of your shaft looks very steep , does the boat get up and plane or plough through the water ?
LarryW
Re: FSB tenby
« Reply #26 on: January 06, 2011, 10:27:04 am »
hi Jon ,it gets up on plane pretty quick and turns are good , 400 speed motor and 7VT power does the trick . oh  30mm prop  :-)) Larry
triumphjon
Re: FSB tenby
« Reply #27 on: January 06, 2011, 12:14:34 pm »
as long it get up to go thats good ! it was just with the angle of those shafts it looks as though it would push the bows down ! props perform better the closer to horizontal that they are running , most modern lifeboats have the props set into tunnels under the hull , as this not only allows a shallower angle but also protects the props ! have you though about using multibladed props yet ?
Ben Tickle
Re: FSB tenby
« Reply #28 on: January 08, 2011, 07:21:21 pm »
I have got a new prop shaft now, which prop would i need, the old prop goes towards the left, would this be left thresed or right threaded?
Ben
Re: FSB tenby
« Reply #29 on: January 08, 2011, 07:48:18 pm »
Most 'Not so modern' lifeboats had props in tunnels
watsons,oakleys etc had hull tunnel props with
plugs that could be taken out from inboard to
cut any ropes etc from the props
LarryW
Re: FSB tenby
« Reply #30 on: January 09, 2011, 10:07:33 am »
hi Ben , try it  it all depends what thread you have i would bought a shaft and prop combo ..... :-)) Larry
Ben Tickle
Re: FSB tenby
« Reply #31 on: January 09, 2011, 04:31:40 pm »
Well i got a 6 inch shaft off ebay which is m4. I also have the spare props from my club 500 so that i can try it out and i will go from there.
Thanks %%
triumphjon
Re: FSB tenby
« Reply #32 on: January 09, 2011, 05:45:46 pm »
just a though re props being borrowed from your club 500 , are they pairs and handed ?
Ben Tickle
Re: FSB tenby
« Reply #33 on: January 10, 2011, 09:15:25 am »
My club 500 props have 2 blades on them! I don't know if this is what you mean.
Ben
Roadrunner
Re: FSB tenby
« Reply #34 on: January 10, 2011, 11:19:20 am »
not to be a bubble burster.. but you have 0 chance of using your club 500 prop on the new shaft you purchased...
reason being simple, the club 500 has a M5 shaft with a 5mm thread so that means the prop also has a 5mm thread..... fitting to a m4 shaft = one lost prop!
LarryW
Re: FSB tenby
« Reply #35 on: January 10, 2011, 02:16:51 pm »
hi  what motor are you useing?>  i run 30mm brass prop on a 400 speed motor  :-)) larry
triumphjon
Re: FSB tenby
« Reply #36 on: January 10, 2011, 09:47:20 pm »
it sound like you need a pair of props with a m4 threaded insert , the thread on each one is the same , but the blade rotation will be different , ie handed , one will need to spin towards the left , the other needs to spin towards the right  ( as you look from the rear of the vessel ) , you will also need to make the motors spin in oposite directions !
Ben Tickle
Re: FSB tenby
« Reply #37 on: January 16, 2011, 05:22:05 pm »
Sorry its been quite a while since the last thread was left, but i am running the standard 400 motor. I am hoping to buy a prop soon. If i only have one prop, which hand does it need to be?
Ben ok2
nhp651
Re: FSB tenby
« Reply #38 on: January 16, 2011, 09:31:11 pm »
i wouldn't say it really matters on a single shaft model boat, either left or right handed,.......it won't make any difference on performance what so ever.
neil
LarryW
Re: FSB tenby
« Reply #39 on: January 17, 2011, 09:38:37 am »
hi welcome back, try 3 blade nylon prop ,30mm  only see what works when you run the boat .by selection of props ,
 mayem have given a few possibles..... good luck ... Larry
Ben Tickle
Re: FSB tenby
« Reply #40 on: January 17, 2011, 02:19:53 pm »
Just a quick thought, when i paint my boat, and then put the waterline on, does it need to be laquered? Only if it isnt i can see it falling off!  >>:-(
LarryW
Re: FSB tenby
« Reply #41 on: January 17, 2011, 02:30:59 pm »
hi Ben , mask of water line using tamiya masking tape purchased at allgood model shops, andpaint in line white humbrol,
 job done    :-))........ LARRY.
Ben Tickle
Re: FSB tenby
« Reply #42 on: January 17, 2011, 07:21:17 pm »
I asked about the laquer because i am going to purchase a role of trimline tape of SHG models,do i need to laquer over it or not?
Ben :-))
LarryW
Re: FSB tenby
« Reply #43 on: January 17, 2011, 07:48:22 pm »
            YES/ O0
Re: FSB tenby
« Reply #44 on: January 17, 2011, 08:09:50 pm »
A little tip for you Ben.
Run the trim line tape from the stern towards to bow and Continue around back to the stern.  The reason being that any joins on the Bow will come adrift and peel back.   :}
Ken
LarryW
Re: FSB tenby
« Reply #45 on: January 17, 2011, 08:18:27 pm »
 thats a very good tip Kenny , but wouldn't you establish water line first/   ........LARRY.
    ps. hows the tugs coming on?
Re: FSB tenby
« Reply #46 on: January 17, 2011, 08:27:47 pm »
Hi Larry,
Thank you. Yes, the tape does not stick to itself very well. To position, I always run a pencil line around first as a guide for the tape.  (use a 5B pencil, not the old HB), as it makes a nice line on the paint and is easily rubbed off afterwards
(going full steam on the tug,  just the trimmings to finish her off)
Ken
LarryW
Re: FSB tenby
« Reply #47 on: January 17, 2011, 08:34:53 pm »
 hi well done don't for get the launch pics , now come on Ben get that tenby on the slip :-))  Larry
Ben Tickle
Re: FSB tenby
« Reply #48 on: January 23, 2011, 10:59:14 am »
Just wondering where to buy the red and yellow stripe from for around the edge?, does this come as one or two seperate stips?
Ben :D
LarryW
Re: FSB tenby
« Reply #49 on: January 23, 2011, 11:53:03 am »
hi ben
         "YES" 2  TRIPS " YELLOW ON TOP RED BELOW ....4 mm wide O0 .....LARRY W.....
Pages: 1 [2] 3   Go Up
Page created in 0.206 seconds with 17 queries.
