Author Topic: mixer problems  (Read 15460 times)
jaguarfold
mixer problems
« on: August 29, 2010, 09:46:55 am »
hi guys i bought the m troniks mixer unit and viper 15 plug n plays when wired up through the mixer i cant get the throttle to do anything the motors run with the rudder but wont turn with throttle unless a bit of rudder is applied any help please
Re: mixer problems
« Reply #1 on: August 29, 2010, 09:58:17 am »
Which mixer unit as none on their website?
Prophet
Re: mixer problems
« Reply #2 on: August 29, 2010, 09:59:46 am »
not sure how to help you with a mtronics mixer never used one nor would given that you can't edit the amount of mixing, as a suggestion, next time get Actions P40 http://www.action-electronics.co.uk/mixers.php
only thing i can suggest is this...
your setup should be , 2 esc --->two motors  1 mixer 1 servo rudder, check you plugged it all in right.
i have found w tails and v tails , but not sure what your using so can't help to much without that infomation both do diffrent things
Re: mixer problems
« Reply #3 on: August 29, 2010, 10:04:19 am »
Also, what radio set are you using?
jaguarfold
Re: mixer problems
« Reply #4 on: August 29, 2010, 10:36:35 am »
using two 600 motors 2 props counter roatating futaba 27mhz rx  tx the mixier is the v-tail  marine mixer had to put y lead to put rudder survo on has 2 viper 15 esc
Prophet
Re: mixer problems
« Reply #5 on: August 29, 2010, 10:48:08 am »
by the looks of it that mixer does not support a rudder servo.. so here's the setup
esc's should plug into one end of the mixer using both cables ( outputs)
one cable from the input should be plugged into the rx unit using port 2 ( throttle) and the other into the rx port 1 ( rudder)
the boat will steer by stopping one motor and speeding up the other giving you a turn
there is NO rudder servo function so remove the rudders and the servo!  i might be wrong but i can't see how.
if you want rudder to work you will need actions P40 mixer
jaguarfold
Re: mixer problems
« Reply #6 on: August 29, 2010, 10:52:52 am »
so its no good for my boat then from what you say its my rudder servo on the y lead thats causing the problem thanks for that have to source new one  {:-{
Re: mixer problems
« Reply #7 on: August 29, 2010, 11:06:23 am »
Prophet,
Yes you are wrong!!
If you connect a "Y" lead into the receiver channel 1 (rudder) you will get uninterupted rudder function.
Have you set up the speed controllers on the receiver channel without the mixer.
I would also recommend a MARINE mixer which will reverse the inner motor when 50%+ rudder is selected.
Prophet
Re: mixer problems
« Reply #8 on: August 29, 2010, 11:12:02 am »
yup im wrong fitting the y lead to the rudder should work, for the rudder must have missed that its to earlie and i have had to little coffee! {-)
jaguarfold
Re: mixer problems
« Reply #9 on: August 29, 2010, 11:14:07 am »
ive set the the esc on there own working fine but when the mixer is plugged in with the rudder no throtle response unless some rudder is applied think im going to action for one of theres should have visited them yesterday but was at the wrong show in birchwood lol
Re: mixer problems
« Reply #10 on: August 29, 2010, 11:46:21 am »
I believe the v tail mixer was designed for aircraft and was supposed to be connected to two servos.
jaguarfold
Re: mixer problems
« Reply #11 on: August 29, 2010, 11:51:23 am »
what would you guys recommend i get then its to run the twin motors and rudder system on my sangetti 1/24 scale fast attack boat
Re: mixer problems
« Reply #12 on: August 29, 2010, 11:54:39 am »
Speak to Dave at Action Electronics he will be able to tell you exactly what you need. :-))
0115 9607951
Re: mixer problems
« Reply #13 on: August 29, 2010, 01:10:47 pm »
Here is a video of one of Dave's mixers in ACTion.
I use this video as the model is light and the propwash can be seen.
This is on a 3 shaft 10 foot hull.
http://media.photobucket.com/video/prinz%20eugen/shipmate600/Picture029.mp4?o=5
Re: mixer problems
« Reply #14 on: August 29, 2010, 03:42:21 pm »
Never seen any V-tail boats. A V-tail mixer is plugged into the Rudder and Elevator channels on the receiver. On application of Rudder command, both servos rotate in the same direction when viewed from above, applying Elevator, both work in opposition. Not much use in a boat, but if you progress to a Sub with X configured tail feathers, it will be some use.  O0
Re: mixer problems
« Reply #15 on: August 29, 2010, 04:29:23 pm »
Almost identical posting to mine, well done, on the ball again ok2
jaguarfold
Re: mixer problems
« Reply #16 on: August 29, 2010, 10:42:14 pm »
thanks guys for your help cant believe it i was sold it by a trader at the birchwoood model boat show for my boat cant trust anyone who wants Ur cash these days  :police:
FullLeatherJacket
Re: mixer problems
« Reply #17 on: August 30, 2010, 07:44:31 am »
I guess his knowledge was limited to what was on the label. We have had a number of customers who have reported that the MTroniks ESCs don't work properly with their mixer.
As one or two folk on this forum have found, the P94 removes all problems of compatilility because everything is in the one box. Suit yourself.
 I still cross my fingers when I watch that video, Bob!
FLJ
Re: mixer problems
« Reply #18 on: August 30, 2010, 11:20:30 am »
  Err, don't think so, you explained what it is, I explained what it does and why and what future use it might be.   %)  :-))
  And just to be Technically correct jaguarfold, if you were using stripped down servos as the propulsion source, a V-tail mixer would work to give selective and joint forward and reverse control.
  Regards  Ian.
FullLeatherJacket
Re: mixer problems
« Reply #19 on: August 30, 2010, 11:55:49 am »
Which type of stripped-down servos would you suggest as suitable power plants for a 1/24 scale  fast attack boat?
FLJ
Re: mixer problems
« Reply #20 on: August 30, 2010, 12:01:48 pm »
Technically
Re: mixer problems
« Reply #21 on: August 30, 2010, 12:11:41 pm »
FLJ
Very large ones ?  {-) Technically %)
FullLeatherJacket
Re: mixer problems
« Reply #22 on: August 30, 2010, 01:04:04 pm »
What - like these, maybe?
http://www.servoshop.co.uk/index.php?pid=FUTS5050&area=Servo
They seem rather expensive to me.
Would Jaguarfold need to rebuild his fast attack boat with X-configured tail feathers, do you suppose?
[This is all getting rather technical, isn't it?  :o ]
FLJ
Re: mixer problems
« Reply #23 on: August 30, 2010, 01:08:02 pm »
Play nicely or I will take the ball away.
Re: mixer problems
« Reply #24 on: August 30, 2010, 01:30:55 pm »
I think it all comes back to the fact that Jaguarfold was talked into buying something that does not do the job he wants it to do.
This surely is down to the trader being economical with the truth although the Mtroniks website does make the point that they
are waterproof therefore intimating they are for marine use.
Must be for seaplanes then :(( :((
Yours Aye
