Author Topic: humbrol paints  (Read 5945 times)
timg
humbrol paints
« on: January 27, 2007, 10:58:22 pm »
Has anyone had any recent issues with the grey128 paint
just bought a few tins, opend one and used (stiring as normal) for it not to give good coverage, tied the others theyre the same too.
Anyone had similar problems.
thanks
tim
Re: humbrol paints
« Reply #1 on: January 28, 2007, 12:23:16 pm »
I use mostly Humbrol 64, but a little while back the mix was changed to make it more air brush friendly.
And gotta say I always stir with the battery operated stirrer, it is superb.
So good that when my first one burnt out I bought another, but repaired it and run it off a 6v 3 ah battery.
I only mentioned this as the pigment can stick to the bottom of the tin.
timg
Re: humbrol paints
« Reply #2 on: January 28, 2007, 02:34:32 pm »
thanks bob,
where did you get the stirer from bob, sounds idea.
ill give anthing a try ONCE  ;D
John W E
  • I see no ships !!
Re: humbrol paints
« Reply #3 on: January 28, 2007, 04:30:38 pm »
Hi all, I made a paint mixer device from a small battery operated 'coffee whisk' bought very reasonably from Ikea - all I did was remove the frothing coil at the end and bent a right-angle in the wire shaft.  Be warned though lads - I have ruined one tee shirt  ;D  and recoloured the walls  ;D in Mountbatten Pink.
There is a remedy to this (which Ive done) get an old tin lid (humbrol tin lid) drill a little hole through the centre of the lid so you pass the shaft of the mixer through and then when you come to mix your paint put the lid on so it gets all the splashing inside. (and not on the outside like what I did lads :P)  Hope that makes sense.
Aye
John E
BLUEBIRD
Knowledge begins with respect
timg
Re: humbrol paints
« Reply #4 on: January 28, 2007, 05:10:43 pm »
good idea, shame about the walls  ;D
guess ill have to come up with a new idea,
like the idea B&Q have where it shakes the cans..(with lids on  ;D )
will have to have a think on that one
John W E
  • I see no ships !!
Re: humbrol paints
« Reply #5 on: January 28, 2007, 05:11:36 pm »
hi spud this is the one I made earlier as they say
aye john e
bluebird
timg
Re: humbrol paints
« Reply #6 on: January 28, 2007, 05:19:48 pm »
thanks for that,,
do you think the wife will realise if i use the one she has...
as long as i clean it before i put it back. ;D
Re: humbrol paints
« Reply #7 on: January 28, 2007, 05:47:47 pm »
Got it from Squires.
Sounds expensive at a tenner, but wouldnt be without it now.
timg
Re: humbrol paints
« Reply #8 on: January 28, 2007, 07:03:52 pm »
thanks bob, ive have their catalogoue ill have a look..
tim
badbunny
Re: humbrol paints
« Reply #9 on: October 03, 2007, 12:36:23 pm »
Who are Squires? I just googled it, but can't find anything obvious...
... just looked again. Is it this company?  http://www.squirestools.com/
Bob, is there a brand / product name I can quote?
Pete.
Guy Bagley
Re: humbrol paints
« Reply #10 on: October 03, 2007, 01:04:23 pm »
look in your local pound shop first,  often my local ones  sell a battery powered coffee frother/ stirrer for your cappucino...
for a pound, all you need to do then is bend  shrink the stirrer bit so it goes in the top of the paint pot, insert your batteries... and bobs your uncle....
Re: humbrol paints
« Reply #11 on: October 03, 2007, 02:06:11 pm »
Paint all over the workshop   ;D ;D
Re: humbrol paints
« Reply #12 on: October 03, 2007, 06:03:10 pm »
Pete.
That's the correct Squires.
They have a Badger Paint Mixer - catalogue code 8121 price £11.99
Squires have no P&P but a minimum order of £10
HTH
Doug
westcoaster
Re: humbrol paints
« Reply #13 on: October 04, 2007, 10:55:37 am »
I've always had good results by simply stirring with a small flat bladed screwdriver. Each to his own, they say and I'm certainlly not criticising anyone but its not so long since we had a very long thread about stirring paint - stirring paint !!. This is nearly as interesting as watching it dry. As the estimable FLJ might say "suit yourself"
Page created in 0.028 seconds with 18 queries.
