Author Topic: 1 Motor 2 shafts  (Read 8414 times)
Perks842
1 Motor 2 shafts
« on: October 04, 2010, 05:27:39 am »
Hello all, Whats the best set up to convert power from one motor to two prop shafts? and where can these set ups be purchased from?
Thanks, Dan
Re: 1 Motor 2 shafts
« Reply #1 on: October 04, 2010, 08:32:38 am »
Can you supply a bit more information about the boat you want to fit it in.
With your username is it a Perkassa? If it is there have been several of these made on here, you might try the search facility.
hopeitfloats
« Reply #2 on: October 04, 2010, 11:37:45 am »
as bob says possibly a bit more information required but on my container ship i used belt drives which seems to work well enough and is reasonably simple to do and quiet running.
mersey dave
« Reply #3 on: October 04, 2010, 12:47:34 pm »
I have never seen this setup, sounds very interesting would it be possible to add some photo's please.
Kind regards Dave.
Perks842
« Reply #4 on: October 04, 2010, 07:07:38 pm »
Was thinking of powering my fletcher class destroyer by 1 motor to save weight and power consumption really, was hoping it wasn't such a rare thing :P
Perks842
« Reply #5 on: October 04, 2010, 07:08:58 pm »
O and no idea on the Perkassa route there
« Reply #6 on: October 04, 2010, 08:10:47 pm »
Perks,
What props are you going to use as the Fletcher kit comes with handed props.
You will need to reverse the rotation of 1 shaft by including 1 extra cog on 1 side only.
A simpler way is to use pulleys on the motor and both shafts.
These can be sized to use neoprene "O" rings to transmit the power.
To reverse 1 shaft fit a slighter larger diameter "O" ring but used in a figure of 8 with the other straight.
Perks842
« Reply #7 on: October 04, 2010, 09:20:15 pm »
Perks,
Thats what I had in mind with the belts, was just hoping there might be some sort of little chassis for it or frame work.
DieselDo
« Reply #8 on: October 04, 2010, 09:26:42 pm »
Some plastic kits do have metal gearboxes, the 1/200 scale Yamato has 4 shaft output.
But these gearboxes tend to be very noisy and you would be lucky to find a box with the exact propshaft width.
« Reply #9 on: October 04, 2010, 09:29:35 pm »
If you look on here in the Gallery you will see Dave Farrows installation in his Fletcher.
http://www.marksmodelbits.com/
Perks842
« Reply #10 on: October 04, 2010, 09:34:03 pm »
Thanks Bob, have already taken a look but like I said, wanted to safe power consumption and weight if the second motor.
« Reply #11 on: October 04, 2010, 09:51:08 pm »
1 problem using 1 motor is that it has to overcome the frictional losses in the gearbox too.
Another way is to fit the motor to 1 shaft and fit 2 identical pulleys and use 1 shaft to power the other with the "O" ring in a figure of 8.
This way ensures you always have drive to 1 shaft.
RaaArtyGunner
« Reply #12 on: October 04, 2010, 11:06:41 pm »
Bob, Nice installation,any ideas how or if the Fletcher images can be saved.
« Reply #13 on: October 04, 2010, 11:13:26 pm »
Ask Mark.
Dave has used exposed shafts and the kit props.
RaaArtyGunner
« Reply #14 on: October 04, 2010, 11:15:31 pm »
Thank you :-))
nick_75au
« Reply #15 on: October 05, 2010, 07:12:02 am »
I would go with two motors, small with low rpm output, will be more efficient than a single motor driving two props,  its the prop causing the amp draw not the motor.
GWS IPS DX2 Motor & Gearbox, about halfway down the page
http://www.micronradiocontrol.co.uk/motor_brushed.html
Will draw minimal current, I've run these on solar cells and 30 mm props. but I also use 3 of the motors by themselves in a 1/72 Snell boot for rocket ship speed :}
Nick
Perks842
« Reply #16 on: October 06, 2010, 07:47:00 pm »
thread no longer requires, thanks all
hopeitfloats
« Reply #17 on: October 07, 2010, 09:09:05 am »
Kind regards Dave.
hopefully the resized picture will load. this is the unit. i have tidied it up a bit by replaced the second hand brass hex and a few other  imperfections since this photo. probably made it more complicated by using ball races from a R/C car and its certainly over engineered but i prefer it that way.
hopeitfloats
« Reply #18 on: October 07, 2010, 09:20:10 am »
maybe a slightly better photo. to give an idea of size, the motor is from a teleprinter (not the prettiest looking but incredibly powerful and quiet)  is approx 45mm dia. x 100mm long. runs 2 x 40mm 3 blade props with virtually no increase in current draw from no load to full load.
