Author Topic: Repainting problems  (Read 2324 times)
chrislang
Repainting problems
« on: October 21, 2010, 11:16:36 am »
I'm in the process of restoring a 34" Aerokits Fireboat that I acquired off ebay.
Unfortunately when trying to spray on an acrylic primer I'm getting an adverse reaction in that the new paint is bubbling / crackling in some areas. I have no idea what the original paint was although it looked to have been brushed on.
Any ideas please for a suitable protective and inert primer / undercoat that I could use to stop this reaction.
Many thanks
Chris
Re: Repainting problems
« Reply #1 on: October 21, 2010, 11:25:33 am »
I am no expert, but I would guess it is an enamel paint.
If brushed on it may be those little Humbrol enamel pots.
You may be able to use Humbrol enamels straight on top.
Do a small test area and see.
Bunkerbarge
« Reply #2 on: October 21, 2010, 11:42:46 am »
I think if you have no idea of what the original is you woul probably be betterrubbing it right back and starting again.  It sounds a bit drastic but it's the only way to really know what you have and you will be safe in the knowledge that nothing is ever going to develop in the future.
Lord Bungle
« Reply #3 on: October 21, 2010, 11:47:40 am »
I am afraid Bunkerbarge is right  :(( only way to be sure if you don't know what the old finish is will be to remove the old paint and start from fresh.  I take it you are spraying over a clean surface so its not oil or silicon spray on the surface thats causing the problem.
triumphjon
« Reply #4 on: October 21, 2010, 07:50:14 pm »
although most people choose to remove all traces of the old paint , YOU DONT HAVE TO  , there is a product available through most repaint factors thats called BARCOAT  , comes in litre sized tins and is ready to spray onto the surface thats reacted , what i tend to do is smooth down the origanal finish then spray this product over the whole job thats being painted , once dry but without rubbing down any further proceed in applying the new paint ! the barcoat seals in the old finish and stops it reacting with whatever you are useing now ! ive had cause to use it many times & its always saved stripping the old paint . hope this helps . jon
Page created in 0.035 seconds with 17 queries.
