Author Topic: what paint brush's do you use ? or are my techniques wrong ? lol  (Read 4468 times)
Dan2010
hi guys . i just wanted to know where to get some paint brushes's that wont leave brush marks ??
like i always go to antics but i always seem to get brush marks, so its either im using the wrong brush, or my techniques wrong .
Dan
woodbutcher
Re: what paint brush's do you use ? or are my techniques wrong ? lol
« Reply #1 on: November 09, 2010, 03:02:58 am »
I use automotive and marine spray paints, thus no brush marks . Al
RaaArtyGunner
« Reply #2 on: November 09, 2010, 04:34:41 am »
Dan,
Water based paints are more foregiving with brush marks.
Peter Fitness
« Reply #3 on: November 09, 2010, 04:45:30 am »
If you are going to use brushes, buy the best you can afford, as they will have much higher quality bristles than the cheap ones, giving a far better finish.
Peter.
« Reply #4 on: November 09, 2010, 05:13:40 am »
Dan ...I find even cheap "black board & green board" areosols @ about $3.00 AUD for a 300gm tin provide a most life like painted meduim & the green tone is pure maritime from years ago  :-)) ....Derek
colin-d
« Reply #5 on: November 09, 2010, 06:47:04 am »
i use badger hair paint brushes... in the sizes 0.5 to 3....
i also use the Humbrol enamel, the small tins, through dabing the paint brush in the thinners, then in the paint, the paint reamins rather liquid on the brush and flows a lot easyer off the brush.
brush strokes allways in the same direction and as long as possible...
the best trick i have been tought is;  once the paint is dry, spray over with a couple of fine coats of satin varnish, the pigments in satin varnish hide the brush strokes.
if you then require a gloss finish spray over with glos varnish..
the attached photo, and my thread HMS Inflexible has been painted in this way.
nemesis
« Reply #6 on: November 09, 2010, 02:56:59 pm »
Hello, the best brush that I have found is obtained at art shops & they have polyester "bristles" you can get them in a variety of widths, I use the 1inch for final coating, it does help, if using gloss paint, to thin just a little so the paint flows.  Nemesis
Mark47
« Reply #7 on: November 09, 2010, 03:36:28 pm »
Flat sable brushes from an art shop, nice soft bristle. :-)) :-)) :-))
Dan2010
« Reply #8 on: November 09, 2010, 10:19:15 pm »
thanks for the adivce guys i sure will be heading out the weekend to get some  :-)
Edward Pinniger
    • Plastic Ship Kit Previews
« Reply #9 on: November 10, 2010, 05:59:01 pm »
Acrylic (rather than enamel) paints also help a lot in avoiding brush marks. They "flatten out" when drying much more than enamels do, and brush marks just disappear! However, they're also less durable + water resistant, so should be sealed with a coat of enamel varnish if used on the hull, especiallly below the waterline.
triumphjon
« Reply #10 on: November 10, 2010, 10:15:05 pm »
ive found that instead of buying my brushes at the art shop , a chain of shops called " THE RANGE "  sells packs of reasonable quality artists brushes for around ten pounds , and have a selection of brushes both flat , round and fine so im able to cover all of my brush painting tasks , although for large areas i normally spray paint them , using both automotive & enamel sprays . jon
Page created in 0.018 seconds with 16 queries.
