Author Topic: RAHIA presentation!  (Read 3227 times)
KBIO
RAHIA presentation!
« on: November 30, 2010, 08:36:13 pm »
Good evening! :-)
As my previous launch, this one has the same hull coming out of the same rig.
The main difference is in the boiler which is vertical. The engine : D10 %) is driving a water pump to supply the boiler from a water tank sticked to the condenser to gain some heat.
I hav'nt done any trial in the lac yet, as the temp is too low, and I hate ice exept in my "Pastis"! {-)
The boiler "Jean paul Bourdillat"  is 125 mm large by 220 high. The burner is ceramic from Stuart. Gas tank is home made and I shall add a pressure regulator to it , to be able to vaporize my gaz mixture and sail when it's cold.  O0
She is not finished yet but I am expecting some fun w/ her! I need to improve  the details as Bernhard! >>:-(
By the way! I think some of you have been to Warwick and met my friends with the big Riva, the Eva faun (supply w/ crane) ,.....According to what they said , they had good time there! I definitly have to come next year ! :-))
Hope you enjoy! ok2
Cheers! :-)
gondolier88
  • www.coniston-regatta.co.uk
    • Coniston Regatta
Re: RAHIA presentation!
« Reply #1 on: November 30, 2010, 10:52:54 pm »
Wow what a model- quality, detail, size everything is just so good.
Can't wait to see it when it's completely finished!
Greg
gamma
« Reply #2 on: November 30, 2010, 11:55:10 pm »
 :-)) it is not yet finished but it is already a great model...please add more pics
kno3
« Reply #3 on: December 04, 2010, 11:46:12 am »
Very nice boat and steam plant. The hull seems very large, how long is it?
« Reply #4 on: December 04, 2010, 12:07:04 pm »
Looks to be approx 24 rib stations in the hull end to end and the Double Ten looks to cover two pitches so ------
J.Walpot.
« Reply #5 on: December 04, 2010, 01:39:50 pm »
Congratulations, just a beautiful piece of work.  :-)) :-)) :-))
Regards, Jan.
KBIO
« Reply #6 on: December 04, 2010, 09:31:44 pm »
Good evening! :-)
115cm X 26cm! O0
Thank you! :-)
KBIO
« Reply #7 on: October 14, 2011, 05:46:19 pm »
Good evening! :-)
The rebound of the RAHIA! :o
As I was unhappy with the performances of my vertical boiler, I succeed to buy a cheap horizontal one from a friend (thanks JC ok2), and by having a larger heated surface , I have better performances out of my D10.
The gas tank is too small and waiting on another one (for Xmas) , I need to pre-heat the boiler with the gas bottle. When the pressure reaches 2.5 Bars , I switch off eveything and I fill up the gas tank. I then can go on in liquid phase. My sailing time on liquid phase is only 20min at "fair" speed. So I definitly need to double gas tank capacity.
The water supply pump works good and keep a constant level in the heater when the by-pass is all shut in.
Just have a few gaskets to change on outlet and to tight some bolts & nuts to be able to deliver "navigation certificate"! %)
I let you see now!
Kind regards!
http://www.youtube.com/watch?v=nYshDRW1SHs
MOG8
« Reply #8 on: October 15, 2011, 05:12:32 pm »
Hi Yves,
what is the diameter of the propeller your D10 is driving?
Nice boat indeed!
KBIO
« Reply #9 on: October 15, 2011, 06:31:49 pm »
Hello Mog8! :-)
The proppeller is 4x blades 90mm. If I had more room, I would have gone for a 120mm, but small boat=small props! ok2
cheers! :-))
Page created in 0.397 seconds with 18 queries.
