Author Topic: Design and build 36" mono  (Read 4505 times)
F1 madness
« on: December 01, 2010, 04:11:38 pm »
Well boredom has set in and iv decided to start a new mono.
36" Long x 9" beam
Got HOR hardware with 3/16 flexi,turns fins,servo mount etc just need to get motor mount.
Also gonna run leopard 4074 2000 kv on 4s/5s and 200 amp ESC
Im designing it with twin stepped deep V hull for the rougher water may also build in a self righting chamber,just not 100% how to do this yet LOL
Will post some pics as soon as i got somthing to 1 of
F1 madness
Re: Design and build 36" mono
« Reply #1 on: December 01, 2010, 09:35:08 pm »
the transom and the 1st 2 bulkheads,and also the the keil/stringer running from from to back.
Will cut these out in the morning,getting late now
triumphjon
« Reply #2 on: December 01, 2010, 11:30:30 pm »
looking interesting , you going to use an air bag for the self righting aid ?
martno1fan
« Reply #3 on: December 02, 2010, 08:23:01 am »
Looks interesting m8 im going to be building a large stepped cigarette hull for next year,well thats the plan anyway  ok2.For you self righting chamber just build a chanel in along one side with holes along the side of the hull and have it open at the transom so when the boat flips this chamber fills up and the boat self rights,the water then runs back out,easy enough to do  :-)).
F1 madness
« Reply #4 on: December 02, 2010, 09:38:05 am »
Hey bud the plan is to install a flood chamber as descibed by mart
Hey mart,cool look forward to seeing how you get on with it,thats what i was thinking with the flood chamber just never done 1 LOL.
I cant decide on how to shape the top yet so just gonna get the main hull done first then have a play with a couple of different designs,but will probably mold this 1 and the other mono,but do a couple of different hatch designs :-))
martno1fan
« Reply #5 on: December 02, 2010, 10:46:30 am »
Nice one,look forward to seeing what you come up with,incidently have you considered trying foam to make the deck plug ? ive had good results using the yellow insulation blocks that have the foil covering,they dont melt when resin is applied so i usually give them a thin layer of sanding gelcoat then sand them smooth for moulding off.Body filler also works ,amazing how fast you can shape something too.
F1 madness
« Reply #6 on: December 02, 2010, 10:54:46 am »
No bud never tried it always used blocks of balsa,but im gonna start and glass cloth them fo radded dink protection and strenght LOL
Thanks for the heads up ill look into it though :-))
F1 madness
« Reply #7 on: December 02, 2010, 10:59:06 am »
Bulk heads are now cut out of 1/4 birch ply and sanded:
now the fun begins.
F1 madness
« Reply #8 on: December 02, 2010, 11:39:40 am »
And another couple of pics:
F1 madness
« Reply #9 on: December 02, 2010, 12:47:24 pm »
Moving right along now some more pics,just working out now for another couple of bulkheads for the front now i can see my lines using the the 6mm squared balsa.
F1 madness
« Reply #10 on: December 02, 2010, 02:11:26 pm »
And some more pics LOL :}
martno1fan
« Reply #11 on: December 02, 2010, 02:56:04 pm »
Your not hanging about m8 are you  :-)),ill be making a start on my new 68" stepped cigarette hull soon using my 58" apache as the basis for the design.Ill stretch it a ft but keep the same width,should work out fine as most apaches at 68-70" are same width as my 58 hull in fact some are narrower.Ill do a build thread showing how i add the steps to the design as well as how i lengthen the plug to make the mould etc.Also i should have the Arrow deck sorted soon,been on the back burner for too long now so hope to have it in production in the new year.
Mart
heres what im aiming for with the Cigarette hull.
F1 madness
« Reply #12 on: December 02, 2010, 03:29:22 pm »
That looks cool,keep me posted on how you get on with them
Daz
martno1fan
« Reply #13 on: December 02, 2010, 05:48:28 pm »
Will do m8
Page created in 0.016 seconds with 19 queries.
