Author Topic: radar drive motor  (Read 8910 times)
Eddy Matthews
radar drive motor
« on: April 28, 2006, 06:41:22 pm »
Does anyone know of a really small motor suitable for a radar drive?
Ideally I'd like something no longer than 1/2" - But is there something that small available?
Eddy
Re: radar drive motor
« Reply #1 on: April 28, 2006, 07:47:58 pm »
Yes, there are some small Swiss geared motors in some of the shows, they rotate at 60 rpm on 3 volts.
They are about an inch long and about a third of an inch diameter.
Also doesnt Alistaire at  model Motors Direct have some motors suitable for radars?
jumpin_jack
« Reply #2 on: April 28, 2006, 08:15:31 pm »
Hi Eddy,
   I use a solar motor drive unit  (item code no 570-454) from squires in Bognor, its the best ?3.95 ive spent in a long time.
especially as the same product from other traders will set you back a tenner, just because they call it a radar motor. ;D
Fast Electricals
« Reply #3 on: April 28, 2006, 10:40:25 pm »
You could always strip out the motor from an old servo. I suggest that you keep the original servo gearbox and cut off the small tab that prevents full rotation of the arm.
Eddy Matthews
« Reply #4 on: April 28, 2006, 10:56:51 pm »
I appreciate the replies guys, thanks.
But a servo motor is too big, as is a Buehler motor or anything that Alistair lists at Model Motors Direct :-(
What are the dimensions on the solar motor you mentioned Jumpin Jack?
Sorry, but I'm really stuck for space to fit this, hence my original message stated 1/2" maximum length - Diameter isn't such a problem, I could probly get away with 1.5" dia, but length is critical...
Eddy
HS93 (RIP)
  • I cannot spell , tough
« Reply #5 on: April 28, 2006, 10:57:26 pm »
Try ? ? http://www.fastcomponents.co.uk/product_info.php?products_id=56&osCsid=ec911a9155d889c0b93d66bbf7fba4af
they are very small 33rpm Miniature Geared DC Motor and work on 1.5v ? Peter
Cargo
« Reply #6 on: April 28, 2006, 11:46:09 pm »
i have found these small ones, Faulhaber Micro-Motor:
15 ? x 12 mm
 3 Volt / 324:1 / 32 Upm
But the price is hot: 44,00 EUR
http://www.faulhaber-group.com/
For example: http://www.faulhaber-group.com/uploadpk/e_1506SR_FTB.pdf
« Reply #7 on: April 29, 2006, 10:17:22 pm »
I recently bought a micro serv for under ?7.00.  Removing the electronics and the stop tab on the output gear should give a small, light motor and gearbox capable of rotating a radar at a reasonable speed.  Or, if you can use a spare channel to control it, just disable the drive to the position sensing pot when you take the stop off the output gear.
Jankers
« Reply #8 on: May 26, 2006, 11:12:50 pm »
Only just read this but if you're srill stuck you could try
http://www.distel.co.uk/asps/details1.asp?ID=KV70
Not done any business with them, just saw the site.
J.
Guy Bagley
« Reply #9 on: June 07, 2006, 09:42:25 am »
Eddy
 i use a tiny electric motor and gearbox that i took out of a LEGO kit,  its red in colour and  15mm x 15mmx 15mm - basically a cube......sadly i dont have any more, but worth a look on say ebay....its happy operating on anything from 3.6volt to  12 volt- the gear ratio is so low geared the increased voltage does not seem increase the output speed  !
JayDee
    • JOHN DOWD
« Reply #10 on: June 07, 2006, 09:58:04 am »
Hello,
In a Mobile Phone, that vibrates to let you know a message has arrived, is the smallest motor I have ever seen!!.
About 1/4 inch dia, less than 1/2 inch long.
The motor shaft had a offset weight on it to make the unit shake while running.
They were on sale at a Computer Fair, but dont know which one !.
Check out the phone folk!.
John.
http://www.john-dowd.
andywright
« Reply #11 on: October 01, 2006, 07:21:05 pm »
Action Electronics do  aneat motor and gearbox for about a tenner. It will run off 6v 0r 12v depending which resistor is fitted, full instructions included.
http://www.actionkit.co.uk/
Navigational Aids vessel Master. Old Conway 70-72
