Author Topic: New Launch  (Read 16842 times)
Underpressure
Re: New Launch
« Reply #25 on: January 14, 2011, 08:12:56 pm »
That is FANTASTIC.
Bernhard, you ARE the master  :-))
Bernhard
Re: New Launch
« Reply #26 on: February 03, 2011, 12:07:35 pm »
Thanks... got the Waterpump from Regner...it will pump the water up from the lake,,,i have use this small RC filter...work OK...nex month Mike will do me a small boiler.......
Bernhard
Patternmaker
Re: New Launch
« Reply #27 on: February 03, 2011, 03:16:32 pm »
Fantastic Bernhard, your work is a inspiration to us all.
Bernhard
Re: New Launch
« Reply #28 on: March 21, 2011, 01:25:13 pm »
got the new boiler  and gastank today from Maccsteam,,,,75mm wide and 105mm tall.......... 6 cross tube in.....28 mm burner  no5 jet ......so now ,,ready to work in the garage
Regards Bernhard
gamma
Re: New Launch
« Reply #29 on: March 22, 2011, 12:49:57 am »
 %) mine will come very soon...Mike made one of his masterpiece for me too
Re: New Launch
« Reply #30 on: March 22, 2011, 05:08:00 am »
Hullo Bernhard....... :D
1. I see a lower boiler water discharge fitting  which could be used for the boiler pilot pressure for a gas regulator  O0
2. but why the two boiler top 90 degree steam discharge valves?  :embarrassed:
Bernhard
Re: New Launch
« Reply #31 on: March 22, 2011, 05:41:35 am »
hi.............1 fore the engine,,,,1 fore the gas regulator pressure,so if i wont, i can close it,,,,,and 1 fore a whistle,,,
Bernhard
Aeronut4
Re: New Launch
« Reply #32 on: March 22, 2011, 06:13:18 pm »
Boy, Mike HAS been busy!  I received my 3" boiler and gas tank yesterday - I'll post a pic when I can get one taken.
Derekwarner_decoy - "I see a lower boiler water discharge fitting  which could be used for the boiler pilot pressure for a gas regulator"  The only fitting I can see like that is actually meant to be feed water inlet to the boiler.  There's also a blow-down on the sight glass, but nothing on the lower part of the boiler that could be fed to a regulator.  Or am I looking in the wrong place?  :D
Re: New Launch
« Reply #33 on: March 22, 2011, 07:44:06 pm »
Aeronut4 ....in image 201.jpg we see
@ 9.00 o'clock a steam isolation valve
@ 6.00 o'clock a steam isolation valve
@ 3.00 o'clock a steam relief valve
The fitting I assumed was suitable for the pilot pressure for the gas regulator is directly below the 6.00 o'clock position but just up from the boiler base.... :o ....however you are also correct  :-)) in that it could be used as a make up water inlet.......Derek
Bernhard
Re: New Launch is READY
« Reply #34 on: March 28, 2011, 02:23:16 pm »
Ready it is,,,,,,,,hope the spring will be here sun,,,,,,,,,,,,,,
        http://www.youtube.com/watch?v=ueqAWDNTO5k
Aeronut4
Re: New Launch
« Reply #35 on: March 28, 2011, 07:17:10 pm »
Oh Bernhard, that looks super! Is that the 'ebay engine'?
Derek - the fitting to which you refer is a feedwater clack valve, so you couldn't use it 'as is' to feed the gas regulator, unless you removed the ball.
Bernhard
Re: New Launch
« Reply #36 on: March 28, 2011, 07:39:08 pm »
hi...........Thanks..OK   .no this is the Puffin,,,the other one is a Plover it is a littel smaller..bot i will try the Puffin first
Bernhard
KBIO
Re: New Launch
« Reply #37 on: March 28, 2011, 07:55:19 pm »
Hello!
Superb Bernhard! From bottom to the wistle! :-)) O0
What's next now? What are going to find to surprise us again? %%
Bravo!
Regards! :-)
Bernhard
Re: New Launch
« Reply #38 on: March 28, 2011, 08:54:11 pm »
hi  Thanks alot...now a break....i think i will enjoy my boats this sommer,,,bot yes it is allways a problem when something is don <:(
Regards Bernhard
Bernhard
Re: New Launch
« Reply #39 on: April 10, 2011, 01:28:27 pm »
hi...i have don this...to take some of the water/oil,,,when it start up...it spit a littel...bot this help....i have all so made the waterpump run on 9 volt..so it will work faster...it will last fore 1  1/2 -2 hour,,,the contact is the rope...
livesteam
Re: New Launch
« Reply #40 on: April 10, 2011, 02:58:18 pm »
impressive work Bernhard!  :-))
Reg Hinnant
Re: New Launch
« Reply #41 on: April 16, 2011, 12:25:12 am »
 :-)) :-)) :-)) Always great! Quick question Bernhard where did you find the rope cleats that you have on the bow & stern. The round one that you have the rope loop over.
Bernhard
Re: New Launch
« Reply #42 on: April 16, 2011, 06:11:13 am »
Thanks.............. it is just some white  robe i did  i find years ago...when i did replica of shrunken heads,,,, and made the color with watercolor,,,,  i normal have get rope from here....i have use that around the steam tube to
   http://cgi.ebay.co.uk/SCALE-MODEL-ROPE-2-0mm-dia-BEIGE-/220757584095?pt=UK_ToysGames_ModelKits_ModelKits_JN&hash=item33662d68df
Regards Bernhard
Re: New Launch
« Reply #43 on: April 16, 2011, 08:41:18 am »
It's the subtle details that make your models stand out Bernhard. How many years of paint are on the hull structure? On the last photo, the build up in the corners aren't unintentional "Sploshing".
  Regards   Ian.
Bernhard
Re: New Launch
« Reply #44 on: April 16, 2011, 02:12:40 pm »
hi  Thanks........... 2 times resin it make the hull so strong and hard,,,..and so 2--3  times good old oil paint.,in and autside ...with a brush....i don't like it to by to clean or perfect...
Regards Bernhard
Reg Hinnant
Re: New Launch
« Reply #45 on: April 18, 2011, 03:19:11 pm »
 :-)) I have purchased rope from Miskins before for my schooner model. Excellent quality!
I was asking about the brass cleat/bollard that is in the center of the bow & stern. It is of a style I am looking for to use on my torpedo stern launch.
I was wondering if you had found those from a supplier or made them.
Thanks!
Bernhard
Re: New Launch
« Reply #46 on: April 18, 2011, 05:13:55 pm »
hi...OK..........Yes,,i made them...
Regards Berrnhard
Reg Hinnant
Re: New Launch
« Reply #47 on: April 18, 2011, 08:06:03 pm »
 O0 Why am I not surprised! {-)
Bernhard
Re: New Launch
« Reply #48 on: May 02, 2011, 08:35:39 am »
Hi....sunday i did try it on the water...Great working engine the Puffin is,and,strong working,,
Bernhard
KBIO
Re: New Launch
« Reply #49 on: May 02, 2011, 07:25:38 pm »
Very nice indeed! :-))
Is it the whistle blowing such a white smoke????
Must be noisy! :}
Cheers!
