August 07, 2025, 02:18:45 am
Welcome,
Guest
Please
login
or
register
1 Hour
1 Day
1 Week
1 Month
Forever
News:
Home
Help
Search
Calendar
Login
Register
The Shipyard ( Dry Dock ): Builds & Questions
Steam
New Launch
« previous
next »
Pages:
1
2
Go Down
Print
Author
Topic: New Launch (Read 16395 times)
Underpressure
Guest
Re: New Launch
Reply #25 on:
January 14, 2011, 08:12:56 pm »
That is FANTASTIC.
Bernhard, you ARE the master
Bernhard
Guest
Re: New Launch
Reply #26 on:
February 03, 2011, 12:07:35 pm »
Thanks... got the Waterpump from Regner...it will pump the water up from the lake,,,i have use this small RC filter...work OK...nex month Mike will do me a small boiler.......
Bernhard
Patternmaker
Guest
Re: New Launch
Reply #27 on:
February 03, 2011, 03:16:32 pm »
Fantastic Bernhard, your work is a inspiration to us all.
Bernhard
Guest
Re: New Launch
Reply #28 on:
March 21, 2011, 01:25:13 pm »
got the new boiler and gastank today from Maccsteam,,,,75mm wide and 105mm tall.......... 6 cross tube in.....28 mm burner no5 jet ......so now ,,ready to work in the garage
Regards Bernhard
gamma
Guest
Re: New Launch
Reply #29 on:
March 22, 2011, 12:49:57 am »
mine will come very soon...Mike made one of his masterpiece for me too
Full Mayhemer
Offline
Wollongong Australia
Re: New Launch
Reply #30 on:
March 22, 2011, 05:08:00 am »
Hullo Bernhard.......
1. I see a lower boiler water discharge fitting which could be used for the boiler pilot pressure for a gas regulator
2. but why the two boiler top 90 degree steam discharge valves?
Bernhard
Guest
Re: New Launch
Reply #31 on:
March 22, 2011, 05:41:35 am »
hi.............1 fore the engine,,,,1 fore the gas regulator pressure,so if i wont, i can close it,,,,,and 1 fore a whistle,,,
Bernhard
Aeronut4
Guest
Re: New Launch
Reply #32 on:
March 22, 2011, 06:13:18 pm »
Boy, Mike HAS been busy! I received my 3" boiler and gas tank yesterday - I'll post a pic when I can get one taken.
Derekwarner_decoy - "I see a lower boiler water discharge fitting which could be used for the boiler pilot pressure for a gas regulator" The only fitting I can see like that is actually meant to be feed water inlet to the boiler. There's also a blow-down on the sight glass, but nothing on the lower part of the boiler that could be fed to a regulator. Or am I looking in the wrong place?
Full Mayhemer
Offline
Re: New Launch
Reply #33 on:
March 22, 2011, 07:44:06 pm »
Aeronut4 ....in image 201.jpg we see
@ 9.00 o'clock a steam isolation valve
@ 6.00 o'clock a steam isolation valve
@ 3.00 o'clock a steam relief valve
The fitting I assumed was suitable for the pilot pressure for the gas regulator is directly below the 6.00 o'clock position but just up from the boiler base....
....however you are also correct
in that it could be used as a make up water inlet.......Derek
Bernhard
Guest
Re: New Launch is READY
Reply #34 on:
March 28, 2011, 02:23:16 pm »
Ready it is,,,,,,,,hope the spring will be here sun,,,,,,,,,,,,,,
http://www.youtube.com/watch?v=ueqAWDNTO5k
Aeronut4
Guest
Re: New Launch
Reply #35 on:
March 28, 2011, 07:17:10 pm »
Oh Bernhard, that looks super! Is that the 'ebay engine'?
Derek - the fitting to which you refer is a feedwater clack valve, so you couldn't use it 'as is' to feed the gas regulator, unless you removed the ball.
Bernhard
Guest
Re: New Launch
Reply #36 on:
March 28, 2011, 07:39:08 pm »
hi...........Thanks..OK .no this is the Puffin,,,the other one is a Plover it is a littel smaller..bot i will try the Puffin first
Bernhard
KBIO
Guest
Re: New Launch
Reply #37 on:
March 28, 2011, 07:55:19 pm »
Hello!
Superb Bernhard! From bottom to the wistle!
What's next now? What are going to find to surprise us again?
Bravo!
Regards!
Bernhard
Guest
Re: New Launch
Reply #38 on:
March 28, 2011, 08:54:11 pm »
hi Thanks alot...now a break....i think i will enjoy my boats this sommer,,,bot yes it is allways a problem when something is don
Regards Bernhard
Bernhard
Guest
Re: New Launch
Reply #39 on:
April 10, 2011, 01:28:27 pm »
hi...i have don this...to take some of the water/oil,,,when it start up...it spit a littel...bot this help....i have all so made the waterpump run on 9 volt..so it will work faster...it will last fore 1 1/2 -2 hour,,,the contact is the rope...
livesteam
Guest
Re: New Launch
Reply #40 on:
April 10, 2011, 02:58:18 pm »
impressive work Bernhard!
Reg Hinnant
Guest
Re: New Launch
Reply #41 on:
April 16, 2011, 12:25:12 am »
Always great! Quick question Bernhard where did you find the rope cleats that you have on the bow & stern. The round one that you have the rope loop over.
Bernhard
Guest
Re: New Launch
Reply #42 on:
April 16, 2011, 06:11:13 am »
Thanks.............. it is just some white robe i did i find years ago...when i did replica of shrunken heads,,,, and made the color with watercolor,,,, i normal have get rope from here....i have use that around the steam tube to
http://cgi.ebay.co.uk/SCALE-MODEL-ROPE-2-0mm-dia-BEIGE-/220757584095?pt=UK_ToysGames_ModelKits_ModelKits_JN&hash=item33662d68df
Regards Bernhard
Full Mayhemer
Offline
North of Watford, South of Hadrians wall
Re: New Launch
Reply #43 on:
April 16, 2011, 08:41:18 am »
It's the subtle details that make your models stand out Bernhard. How many years of paint are on the hull structure? On the last photo, the build up in the corners aren't unintentional "Sploshing".
Regards Ian.
What I said is not what you think you heard.
Bernhard
Guest
Re: New Launch
Reply #44 on:
April 16, 2011, 02:12:40 pm »
hi Thanks........... 2 times resin it make the hull so strong and hard,,,..and so 2--3 times good old oil paint.,in and autside ...with a brush....i don't like it to by to clean or perfect...
Regards Bernhard
Reg Hinnant
Guest
Re: New Launch
Reply #45 on:
April 18, 2011, 03:19:11 pm »
I have purchased rope from Miskins before for my schooner model. Excellent quality!
I was asking about the brass cleat/bollard that is in the center of the bow & stern. It is of a style I am looking for to use on my torpedo stern launch.
I was wondering if you had found those from a supplier or made them.
Thanks!
Bernhard
Guest
Re: New Launch
Reply #46 on:
April 18, 2011, 05:13:55 pm »
hi...OK..........Yes,,i made them...
Regards Berrnhard
Reg Hinnant
Guest
Re: New Launch
Reply #47 on:
April 18, 2011, 08:06:03 pm »
Why am I not surprised!
Bernhard
Guest
Re: New Launch
Reply #48 on:
May 02, 2011, 08:35:39 am »
Hi....sunday i did try it on the water...Great working engine the Puffin is,and,strong working,,
Bernhard
KBIO
Guest
Re: New Launch
Reply #49 on:
May 02, 2011, 07:25:38 pm »
Very nice indeed!
Is it the whistle blowing such a white smoke????
Must be noisy!
Cheers!
Print
Pages:
1
2
Go Up
« previous
next »
Steam
New Launch
