Hello folks could you please help me understand or point me in the right direction whereby I can learn a little more as the title suggests ?
Many times I have read posts advising (using hypothetical figures for eg only) a motor of say 7.2volts to be run using a 8.4, 9.6 or even far higher voltage batteries to give (I assume) much more power, firstly does this not go outside of the designed voltage specification for the motor? Also by 'power', is this speed via increased rpm or torque or both? I do realise of course, that all set ups are defined by the type of craft to be driven but I'm trying to get a general understanding of how you guys determine this.
I've read a few basic articles on motors / batteries / props / esc's etc. but finding the right combination is where I'm totally lost. An excellent example is a post by Lord Bungle re his underpowered boat - Spear, this also brings into play the question of weight, as a novice I assumed all craft even the fast (ish) planing ones were built to a waterline, in which case would this not decide the overall weight needed / acceptable, or am I completely barking up the wrong tree?
May be asking a lot I know but If anyone could help with a basic tutorial, a general overview or even constructive opinion I'd be most grateful, thanks in anticipation and kind regards,
Tony.
